KARAOKE SCENE MAGAZINE ONLINE! - speaker question Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Tue Nov 03, 2026 1:51 am
 Post subject: speaker question
PostPosted: Thu Jan 12, 2006 2:20 pm
need advice on speakers...
Yamaha S215V
Yamaha S112V
Yamaha S1115V
are any of these 3 decent speakers?
If not what kind and where can i find decent sounding speakers with at least these specs...  400 watt/ 800 peak 8ohms... for a reasonable price....
any advice would be appriciated...
Thanx again  :)
 Post subject: Re: speaker question
PostPosted: Thu Jan 12, 2006 3:09 pm
Yamaha S215V
Yamaha S112V
Yamaha S1115V
Thanx again  :)
The S112V & S115V are good speakers.  Which to get depends on how you need to use them.  If you are just needing some for home use, the S112V will be fine, if you are doing club work, then the S115V will be a better choice.  Remember basic rule of thumb is to make sure your amp pushes at least the RMS rating (not peak rating).  So for a speaker that handles 400 watts/800 peak - into 8 ohms, your amp should at least push close to the 400 watt range into 8 ohms for maximum efficiency & less chance of blowing the speaker.
PostPosted: Fri Jan 13, 2006 8:24 am
I use the Yamaha S115Vs for my main cabs and a Yamaha BR12 for my monitor. I don't think there is a speaker out there under $1000/pair that has the bass responce of the Yamaha S115Vs. I work in about a 6000/sf bar and play to about 80-100 nightly and these babies have sparkling highs, good vocal mids, and bass that vibrates the back windows....
I run the SV115Vs off of a Yamaha P5000S Dual Channel Power Amp, and the Yamaha BR12 off of a separate Samson Servo amp that I bridge just for the monitor.
Users browsing this forum: No registered users and 2185 guests
