I think you mean "copying" so I will try to answer it seriously this time... ok you will need some cardboard, Elmer's Glue, a sharp pencil, safety scissors, a box of 64 color crayons and an adult to help supervise... first you will need to sniff the whole bottle of glue to make this work... take your karaoke CD and place it gently on the cardboard... take the sharp pencil (be careful!) and draw around the outside of the karaoke CD... remove the karaoke CD and use your safety scissors to cut the outline of the CD from the cardboard... have the adult supervising help you if you have trouble... once the cardboard CD is cut out, proceed to use the mass array of colored crayons in your arsenal to whip up whatever cool artwork you want on the CD... be sure to color on only one side or the CD will not play correctly when you are finished... remember that some CDG players will not play copied discs and some KJ's will not play them in their machines... repeat above steps for as many karaoke CD's as you want... have fun...- tig
Joined: Thu Nov 07, 2002 2:40 am Posts: 7468 Location: Kansas City, MO Been Liked:1 time
heheheh
babs, this topic has been covered ad nausum in this and othe forums. All you have to do is click the "forum search" in the member area (black section off to the left there).
Users browsing this forum: No registered users and 2185 guests
