KARAOKE SCENE MAGAZINE ONLINE! - Karaoke experts -please help Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Wed Nov 04, 2026 6:10 am
PostPosted: Thu Dec 29, 2005 1:45 pm
I posted before, but didn't have all the information for you. You were so helpful before I'm hoping you all can give me expert advice again. Please remember I am not so formiliar with a lot of the technical jargon.
I finally found my power amp specs. It is an old amp, so it was difficult.
Please keep in mind I work in a small bar. I am excited about hearing your input.
Thank you -
My main questions are do I need more power?
And how do I set my 8 band equilizer?
I have 3 JBL Eon speakers (2 for mains, 1 for a monitor) http://www.musiciansfriend.com/srs7/g=live/search/detail/base_pid/600226/
Yorkville MP8 powered mixer  http://fmsystems.net/sp_mp8.htm
Cavs JB 199 premier karaoke jukebox http://www.cavsusa.com/jb-199-premier.html
2 - Audix OM2 mics http://www.musiciansbuy.com/AUDIX_OM2_MIC_WITH_FREE_CABLE.html
1 - Audio Technica 3000 series wireless mic http://namm.harmony-central.com/SNAMM02/Content/Audio-Technica/PR/3000-Series.html
PostPosted: Thu Dec 29, 2005 5:17 pm
 You should have enough for now for a small bar.  I would check into getting an external efx unit,  mic compressor, bbe36 and maybe an aphex 104 or 204....
 Almost flat you can trim the bass as necessary Those eons will take it just dont run the main outs all the way up.. I run mine -3 to -6db.  If you have to run everything hot you need more power.....
PostPosted: Thu Dec 29, 2005 5:54 pm
The speakers you posted are POWERED speakers....They have their own amps inside, so your mixer amp is not an issue.
If in fact those are the correct speakers, then they do not offer much in the way of power.
If you showed us the wrong speakers and you are actually using the amp built into your mixer, you have even less power.
Your mixer can only deliver 100 watts at 8 Ohms to each the left and right speaker IF YOU ARE NOT USING POWERED SPEAKERS.
Either way, you are way short on power if you expect to fill any average sized venue.
PostPosted: Fri Dec 30, 2005 12:49 am
woops I posted the wrong speakers
They are Eon passive not powered http://www.musiciansfriend.com/srs7/g=live/search/detail/base_pid/600226/
Yikes it looks like even less power -
I am running a monitor also
Karyoker - you mentioned getting a few more items, but I don't know what they are or what they do. Help please.
PostPosted: Fri Dec 30, 2005 2:10 am
It looks to me that you are grossly under-powered; your amp is only 100w while your speaker can handle 225w rsm. This is a very gross missmatch and may lead you to cliping the amp and blow your horn.
You will be better off having a small mixer (a 6 channel), and an amp that give at least 225w per channel at 8ohm to match your speakers. Then use the amp mixer to power the third speaker.
Just my 2 cent
PostPosted: Fri Dec 30, 2005 6:03 am
I agree with that statement.
I'd rather go for a Peavey or Crown amp, with a stand alone mixer to replace your Yorkville MP8.
PostPosted: Fri Dec 30, 2005 8:36 am
Okay if I ditch my old amp and get a new amp and a mixer what do you suggest I get to go with my speakers. Remember I use 2 passive JBL Eons for mains and 1 for a monitor. I may also want to add a sub in the future.  :D
PostPosted: Fri Dec 30, 2005 9:11 am
Babs,
Your options for more power and a mixer are endless.
I'm sure you will get some ver good advice here.
I migt have missed it but what is your total budget for a new amp and mixer ?
PostPosted: Fri Dec 30, 2005 10:38 am
The new amp and a mixer will be driving your speakers.
PostPosted: Fri Dec 30, 2005 11:03 am
Ok here is one possiblity
  Since Jbl recommends an amp that is twice the continuous speaker rating, an amp close to  500 watts  would work.... The 1500's are 225 watts....
A Mackie 808m would supply 450 watts into 4 ohms.. Thus you coluld run your 2 mains from the left channel and run your monitor from the right channel...
PostPosted: Fri Dec 30, 2005 11:04 am
You should have more power for the speakers.  100 watts is not enough - does't matter the size of the room, the speakers are being underdriven, especially if you get nights that might need the volume up "just a bit more".  Your amp should push at least (bare minimum) 225 watts per channel into 8 ohms.  I personally would look for an amp that pushed about 400-500 watts per channel into 8 ohms.  What this does is basically keeps the headroom available, you won't need to turn the system up as high, you will get a MUCH fuller sound & cleaner to boot.  With the lower power amp (lower headroom), it hits into clipping (distortion), you have nothing more to push as far as volume EXCEPT distortion.  One thing to remember, you may not even notice the distortion, but your speakers will!!!
PostPosted: Fri Dec 30, 2005 9:14 pm
I suggest the Peavey PV1500 amp.
It will deliver 300watts to each main at 8 Ohms in stereo and includes a 40Hz low cut filter to protect the mains from too low freqs at high sound levels...The low filter also preserves amp headroom.
A little too much amp is a good thang.
Hon, you ain't really heard your speakers yet...You will like them lots more once you give them more amp.
PostPosted: Sat Dec 31, 2005 11:42 am
Great ideas already - please keep them coming - I value your imput - I'm going to take your suggestions then do my homework
I'm willing to spend around $1000 for both amp and mixer.
Thank you for the responses so far :worship:
PostPosted: Sat Dec 31, 2005 1:08 pm
Babs @ Sat Dec 31, 2005 11:42 am wrote:
Great ideas already
If that were my budget I would probably pick up the Crown XLS602 & a Mackie CFX12.
PostPosted: Sat Dec 31, 2005 2:19 pm
oh yeah - I'm liking that crown amp. It is only 27 lbs with the right amount of power.
Users browsing this forum: No registered users and 2644 guests
