KARAOKE SCENE MAGAZINE ONLINE! - converting .kar files Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Mon Nov 02, 2026 1:53 pm
 Post subject: converting .kar files
PostPosted: Fri Nov 11, 2005 7:07 am
Is there any way to convert .kar files to mp3s??  I tried to use DBPoweramp to do it, but the kar file doesn't even show up as an option to choose.
PostPosted: Fri Nov 11, 2005 7:34 am
.kar files are midi with lyric. There must be an audio software that read midi file but I dont think it will retain the graphic. My way is to record it.
Band-In-A-Box should be able to convert the file to wav directly. From wav.-->mp3
PostPosted: Mon Nov 14, 2005 4:00 pm
Thanks...I downloaded a .kar file by accident and wasnt' sure what to do with it.
PostPosted: Mon Nov 14, 2005 4:38 pm
There are tons of .kar files on the Net and are mostly free(for home use). At home I use them alot for singing practice esp. when I dont have the real tracks. If you have Band-in-A- Box you can do a lot to it.
A free software that you may want to try is lyrics4You. Its a midi player that can do more and have a funtion where you can add in the lyric to a midi file if it does not have one. The guy who write it is a member to this forum. google lyrics4You
PostPosted: Mon Nov 14, 2005 4:41 pm
Thanks, I will check it out, that sounds like a good alternative if you just want to practice a song to perform that you won't be posting here.
I appreciate your help!
-Allison
PostPosted: Mon Nov 14, 2005 4:52 pm
And a good search engine for midi/.kar file is http://www.vanbasco.com/
PostPosted: Sun Nov 20, 2005 2:44 pm
Been Liked: 8 times
PowerKaraoke can be used to convert KAR to CD+G/MP3+G. The quality however depends on your soundcard, as it will be used to convert MIDI (KAR) to regular WAV audio file.
PostPosted: Sun Nov 20, 2005 4:14 pm
Dang JB!,
You are kinda cute!
XOXOXOXO!
Users browsing this forum: No registered users and 2035 guests
