Joined: Tue Apr 06, 2004 10:18 pm Posts: 4080 Location: Serian Been Liked:1 time
.kar files are midi with lyric. There must be an audio software that read midi file but I dont think it will retain the graphic. My way is to record it.
Band-In-A-Box should be able to convert the file to wav directly. From wav.-->mp3
There are tons of .kar files on the Net and are mostly free(for home use). At home I use them alot for singing practice esp. when I dont have the real tracks. If you have Band-in-A- Box you can do a lot to it.
A free software that you may want to try is lyrics4You. Its a midi player that can do more and have a funtion where you can add in the lyric to a midi file if it does not have one. The guy who write it is a member to this forum. google lyrics4You
Joined: Tue Jun 15, 2004 1:41 pm Posts: 219 Been Liked:8 times
PowerKaraoke can be used to convert KAR to CD+G/MP3+G. The quality however depends on your soundcard, as it will be used to convert MIDI (KAR) to regular WAV audio file.
Users browsing this forum: No registered users and 2087 guests
