| Mixer https://ksmo.us/forums/viewtopic.php?f=1&t=5601 |
Page 1 of 2 |
| Author: | twient [ Fri Oct 28, 2005 7:41 am ] |
| Post subject: | Mixer |
Anyone have an opinion on the best rack-mountable 3 mic (at least three...more is fine), 4 channel mixer out there? Maybe one with built-in effects (although I have a seperate component for that)? Thanks |
| Author: | Tony [ Fri Oct 28, 2005 7:44 am ] |
| Post subject: | Re: Mixer |
Hoopla, here we go, another can of worms was just opened up
Here my favorite: http://www.behringer.com/UB1204FX/index.cfm?lang=ENG Come on guys (and dolls) let's hear it! |
| Author: | kjgreg [ Fri Oct 28, 2005 8:55 am ] |
I would look at Mackie CFX12. My personal opinion |
| Author: | Lonman [ Fri Oct 28, 2005 9:06 am ] |
kjgreg @ Fri Oct 28, 2005 8:55 am wrote: I would look at Mackie CFX12. My personal opinion
2nd! |
| Author: | twient [ Fri Oct 28, 2005 10:45 am ] |
Those look good. Thanks. Does anyone know of any that are the prototypical rack mounatable type? |
| Author: | Lonman [ Fri Oct 28, 2005 10:47 am ] |
twient @ Fri Oct 28, 2005 10:45 am wrote: Those look good. Thanks.
prototypical rack mounatable type? They all can be racked. The ears are usually purchased separately depending on the brand. |
| Author: | twient [ Fri Oct 28, 2005 10:50 am ] |
http://www.numark.com/index.html?http:/ ... rview&n=77 How about this one? |
| Author: | Lonman [ Fri Oct 28, 2005 10:53 am ] |
twient @ Fri Oct 28, 2005 10:50 am wrote: http://www.numark.com/index.html?http://www.numark.com/products/product_view.php?v=overview&n=77
How about this one? If it's MADE for karaoke, it generally isn't worth it's weight in parts. Stick with a pro unit, you'll be glad you did! What does your system consist of now? |
| Author: | lyquiddye [ Sat Oct 29, 2005 1:13 am ] |
Behringer is Noisy and Junk I dumped my Behringer mixers for Yamaha and can't believe the difference. I have Yamaha 16/4's now they are big bu many times I do sound for bands now an then so the extra channels made sense. Plus it is the size of the top of an SBK Gig Rack, they fit perfect. You will find the Yamaha mixers to be slightly less in price than the mackies and have much warmer mic pre amps. There are versions with and without onboard effects the effect models are about $100 more. If you need a very inexpensive mixer Behringer will work. but only the mic channels have gains, on the yamaha the stereo inputs also have gain controls. The faders are not the best, and the mic pre amps are less than to be desired. I still have 2 behringer mixers myself, after 3 years in operation they are still 98% functional, so I guess they were more than worth their money, my yamaha Mixers were only $230 after a discount and the Street price is $270 you can get a 12/4 for $230 only $100 more then the same Behringer I suggest spending the little extra cash, you will not regret it. |
| Author: | twient [ Mon Oct 31, 2005 8:28 am ] |
Right now, I have a Stanton (POS) in place. It is a backup...I used it for the first and ONLY times Friday and Saturday. Never again. Yeah, I need a 19" mixer that I can use for standard DJing as well. |
| Author: | jamkaraoke [ Mon Oct 31, 2005 9:10 am ] |
twient I just picked up a behringer 1222fx rackmounted unit. I've used the Mackied DFX12 in the past and feel this unit is on the same level as the Behringer. (soundwise) Only time will tell if it holds up . This unit for the money was and is worth every penny. On Boards effects which in my opinion for karaoke MUCH better than the DFX12. also the Behringer unit has 7bnd main eq / 3band Channel EQ / feedback finder / 3d surround effect / There is a lot of truth in the old addage you get what you pay for... So you need to decide if you want to pay $600 for a Mackie CFX12 or $179 for a Behringer. You can drive a Chevy or you can drive a Lexus --both have power steering AC and a radio, Both get you from point A to point B in comfort.... |
| Author: | karaokemeister [ Mon Oct 31, 2005 10:37 am ] |
The 'best' is a subjective term. But since you said you want to use it for DJ'ing as well things can get pretty strange. I'm assuming a 19" rackmount since you didn't say you were using a 10". Best? Heath and Allen Xone 464 kicks (@$%!).... ($1500 or so) but reasonably priced? The CFX is a good choice - especially if you need internal effects. I use a Mackie Onyx 1620 ($750 or so) because I wanted the extra recording capabilities. I can also hook this together with another 1620/1640/1220 to increase the number of channels I can record. Overkill? Yes. Hard to rack? Yes (it's 12U). But bang for the buck with the extra recording capabilities a Mackie Onyx 1220 is a good buy (but will require an external effects unit). BTW, rack ears for a 1620 are $50, but come with the 1640 (but it's $1200 and has NO stereo inputs). |
| Author: | jamkaraoke [ Mon Oct 31, 2005 12:09 pm ] |
I guess if he is using for DJ also ..some type of cross fader is required which limit your choices? |
| Author: | Lonman [ Mon Oct 31, 2005 12:15 pm ] |
karaokemeister @ Mon Oct 31, 2005 10:37 am wrote: Best? Heath and Allen Xone 464 kicks .... ($1500 or so)
Oh BY FAR the best board for BOTH KJ and DJ. If it weren't for the price tag, it would be the ultimate board! |
| Author: | twient [ Mon Oct 31, 2005 12:20 pm ] |
How about this one? I'd like to stay under a grand. http://www.americanmusical.com/item--i-PIO-DJM3000.html |
| Author: | twient [ Mon Oct 31, 2005 12:21 pm ] |
...and yes, need the crossfader... |
| Author: | Lonman [ Mon Oct 31, 2005 12:38 pm ] |
twient @ Mon Oct 31, 2005 12:20 pm wrote: How about this one? I'd like to stay under a grand.
http://www.americanmusical.com/item--i-PIO-DJM3000.html Won't be much use for karaoke. Good dj board. That's the one thing, if you are running karaoke, you need something designed for more live work, dj boards are set-up to play music pretty much & not designed to work with live vocals. you may consider getting a small 'live" mixer to handle the karaoke aspect & the dj mixer for the dj aspect. A friend of mine does this & it works fine, he connects the dj board to the live board when he needs to do both karaoke & dj work. Otherwise he runs one or the other if it's just strictly one or the other. |
| Author: | Jian [ Mon Oct 31, 2005 3:16 pm ] |
Lonman @ Tue Nov 01, 2005 4:15 am wrote: karaokemeister @ Mon Oct 31, 2005 10:37 am wrote: Best? Heath and Allen Xone 464 kicks .... ($1500 or so) Oh BY FAR the best board for BOTH KJ and DJ. If it weren't for the price tag, it would be the ultimate board! Anyone know which store stock it? I want steal afew LMAO
| Author: | Donny B [ Mon Oct 31, 2005 7:23 pm ] |
You guys are gonna get a chuckle out of this. For KJ I still use a Gemini KM 707. :worship:
Donny "B" |
| Author: | Micky [ Tue Nov 01, 2005 2:05 pm ] |
What a great subject
Todays best buy would be the new Yamaha 12/4FX or the 16/4FX, a little more expensive than Behringer but offers a much better DSP and the customer service is by far superior. Mackie are way over priced and do not offer a better sound or mic pre-amp, in fact, any board under $1000,00 will have a crapy Mic pre-amp that will give you similar results, but for Karaoke it's still fine. I own a Behringer 1622fx-Pro and never had any problems, it has a crapy DSP but don't care, cause I'm using a Lexicon MPX-110 along with a DBX 266XL and my latest addition allows me to bypass the mic pre-amp by using a lamp pre-amp call, TUBE Pre from Prosonic, day & nights difference Again, YAMAHA has the best buy product has we speak and thanks to Behringer for making the others lower their prices
