KARAOKE SCENE MAGAZINE ONLINE! - What is the best Disc to burn to? Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Mon Nov 02, 2026 1:26 pm
PostPosted: Tue Oct 25, 2005 4:03 am
is there a difference in Disc's? Ive been using all kinds and would like to narrow it down to the best manufactuer. What kind do you use to compile your Custom Karaoke Disc?.
Michael
PostPosted: Tue Oct 25, 2005 6:23 am
Mitsui Gold.  These are special order discs but the best for longevity & final product.
PostPosted: Wed Oct 26, 2005 2:59 am
Thanks Lonnie  Just ordered 50 ,,they will be here friday :)
PostPosted: Thu Oct 27, 2005 1:07 am
I have found that TDK Black CD-r work very well and hold up much longer than any other cd-r.
PostPosted: Thu Oct 27, 2005 1:29 am
The black discs i've tried (TDK, Memorex) worked GREAT at first but haven't had the longevity as the gold discs - meaning i've needed to re-do within a year.  The only ones that have worked faithfully through the years (14) are the Mitsui gold.
PostPosted: Thu Oct 27, 2005 1:35 am
Cool, I don't burn other than to tranfer data when I an too lazy to hook up a usb drive. I will have to check out a spindle of the disc you reccomend and use them for inportant data.
Originally it was said that a CD-A are manufactured to last 100 years but I end up scratching my cd's they will never last that long. I go my 1st cd player in 1985 so 20 years now wow that is hard to believe, I have only a few of my original cd's.
The original cd-r was given a life of 10 years. None of my 1st cd-r's are still operational. The 2x cd burner still works though!
PostPosted: Thu Oct 27, 2005 8:02 am
I checked out those "gold" discs.... They must really be made of gold......
They're like $.95 each ....  But according to the specs have some sort of patented layer of protective coating which is why they HOLD up longer .....
PostPosted: Thu Oct 27, 2005 10:36 am
Like I said I have backups from 1996 that are working just as good today as the day they were burnt.
PostPosted: Fri Oct 28, 2005 3:20 am
Got My disc's A day early ..
very impressed with the way they look...I got 50 for $75 buck's. I dont mind spending the money for quality.
I'll be burning on em this weekend .
Thanks again Lonnie
Michael
PostPosted: Fri Oct 28, 2005 7:35 am
Thanks again Lonnie
Michael
Sounds like you got the "archival" grade - those are generally a little more.  I've seen the regular "gold" discs as low as .65 per disc in bulk before.
Users browsing this forum: No registered users and 2119 guests
