C.D. Labels
https://ksmo.us/forums/viewtopic.php?f=1&t=5502
Author:  gator [ Thu Sep 29, 2005 3:47 pm ]
Post subject:  C.D. Labels
On my fast tracks program Im able to print C.D. Labels what type of paper should I use so I can attach them to the C.D.? Thanks in advance.
Author:  Tigrr27 [ Thu Sep 29, 2005 4:01 pm ]
Post subject:  Re: C.D. Labels
probably pre-made attacheable CD labels that match your program printing format...
Author:  eben [ Thu Sep 29, 2005 10:50 pm ]
Hi. I use Fasttrack as well and I print out the labels on my laser printer. If you print on a ink jet, you may have to get a different kind of label or it may smear. The one I use for the laser printer is Avery number 5698. It's 100 labels in 50 sheets and you don't even have to align anything from the program, it printed out fairly centered without any adjustments. Only thing is that it may cut out a word or two on long lists on lower left hand side but usually it's not too bad.
As I said, check the box at your local stationary store and use the right label on your printer. Good luck.
