KARAOKE SCENE MAGAZINE ONLINE! - songbook Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Mon Nov 02, 2026 3:54 am
 Post subject: songbook
PostPosted: Fri Sep 09, 2005 11:08 am
I'm doing new books in excel, I've forgotten how to double column, worked an hour , I need help.....thanks
 Post subject: Re: songbook
PostPosted: Fri Sep 09, 2005 12:00 pm
If you have MS Access, you can use the Excel's MS Access Links add-in to create an Access report (under the Data option).  From there, do a two-column page set-up.  That Wizard is a bit limited though.  If you are familiar with Access, you can simply link to the Excel table and create a report in the report designer.   Otherwise, working solely within Excel, it would be difficult without a lot of manual intervention - Excel (to my knowledge) is not capable of doing the multicolumn type report I think you're referring to.
Sounds Great! Entertainment
Bartlett, Illinois
PostPosted: Fri Sep 09, 2005 9:00 pm
Put your pointer between A & B..it will turn it into a cross..now drag to the right ....or left..depending how big you want your column. Do it between B&C...etc.
Users browsing this forum: No registered users and 1653 guests
