| Home system question https://ksmo.us/forums/viewtopic.php?f=1&t=5384 |
| Author: | Mike981 [ Mon Aug 29, 2005 6:25 pm ] |
| Post subject: | Home system question |
God I hope I am not beating a dead horse here, I have spent several days searching the forums and yet to come up with the info. I am looking to step up to a decent/good home system. It will be used in a rather small room, about 400 sq feet. I don't need to compensate for anything (I don't plan to entertain much), so I am just looking for the best sound for the $$. Right now I have a $200 Fleco system run through my surround sound. As for a price point, I would like to keep it under $1000. I have the music, I just need help to make me sound better...
| Author: | karaokemeister [ Tue Aug 30, 2005 3:39 am ] |
| Post subject: | Re: Home system question |
Ok, try the Fender PD-150. It's 150 watts, the speakers were designed by Bose, and it's a basic all-in-one type of system. There are a lot of other options out there but connect up your existing player, plug in a mic and you're singing in a matter of minutes. 150watts should be more than enough for a room that size BTW. Of course Lonman and others here have more experience and I hope they chime in.... You can check Target ad for new products. |
| Author: | Mike981 [ Tue Aug 30, 2005 4:47 am ] |
Thanks for the tip karaokemeister. I will give that unit a look see. I was thinking more along the line of piecing some components together. Then as time and money allow, I could upgrade. Maybe my budget isn't in line with that thinking. FWI, I don't have a problem going the ebay way. |
| Author: | TopherM [ Tue Aug 30, 2005 8:57 am ] |
Here's a good, cheap route for a good home starter set you could upgrade later: Behringer PMH660M powered mixer (200 watts per channel, 8 channels, with FX) -$250 at Musician's Friend Peavey PV115 Speakers (15" woofers, 300Watt continuous handling) - $199 each. Samson R21 mics $49.99 for three at SamAsh (through you probably already have mics) Mic cables, speaker stands - About $50-60 total ( you may have this as well). That's about $650-800 for a good, upgradable home system You could upgrade the sound later by adding a BBE 362 Sonic Enhancer ($99, will INSTANTLY upgrade your final mix!!), external amp(s), monitor speakers, etc. |
| Author: | TopherM [ Tue Aug 30, 2005 8:59 am ] |
Oh, and use your current player in this setup, though for faster seek times and less skipping, you could upgrade to a professional player like the RSQ 333 later as well... |
| Author: | Mike981 [ Tue Aug 30, 2005 1:51 pm ] |
Thank you TopherM. That is the idea I was thinking of. The ability to upgrade as we go. I am not sure I want to use this Fleco system as the player. We have had problems with it pausing on it's own durring playback. A major pain in the arse. I think we will donate it to my wifes daycare. |
