KARAOKE SCENE MAGAZINE ONLINE! - Home system question Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Mon Nov 02, 2026 3:47 am
 Post subject: Home system question
PostPosted: Mon Aug 29, 2005 6:25 pm
God I hope I am not beating a dead horse here, I have spent several days searching the forums and yet to come up with the info.
I am looking to step up to a decent/good home system.  It will be used in a rather small room, about 400 sq feet.  I don't need to compensate for anything (I don't plan to entertain much), so I am just looking for the best sound for the $$.
Right now I have a $200 Fleco system run through my surround sound.  As for a price point, I would like to keep it under $1000.  I have the music, I just need help to make me sound better... LOL
 Post subject: Re: Home system question
PostPosted: Tue Aug 30, 2005 3:39 am
Ok, try the Fender PD-150.  It's 150 watts, the speakers were designed by Bose, and it's a basic all-in-one type of system.
There are a lot of other options out there but connect up your existing player, plug in a mic and you're singing in a matter of minutes.  150watts should be more than enough for a room that size BTW.
Of course Lonman and others here have more experience and I hope they chime in....
You can check Target ad for new products.
PostPosted: Tue Aug 30, 2005 4:47 am
Thanks for the tip karaokemeister.  I will give that unit a look see.  I was thinking more along the line of piecing some components together.  Then as time and money allow, I could upgrade.  Maybe my budget isn't in line with that thinking.
FWI, I don't have a problem going the ebay way.
PostPosted: Tue Aug 30, 2005 8:57 am
Here's a good, cheap route for a good home starter set you could upgrade later:
Behringer PMH660M powered mixer (200 watts per channel, 8 channels, with FX) -$250 at Musician's Friend
Peavey PV115 Speakers (15" woofers, 300Watt continuous handling) - $199 each.
Samson R21 mics $49.99 for three at SamAsh (through you probably already have mics)
Mic cables, speaker stands - About $50-60 total ( you may have this as well).
That's about $650-800 for a good, upgradable home system
You could upgrade the sound later by adding a BBE 362 Sonic Enhancer ($99, will INSTANTLY upgrade your final mix!!), external amp(s), monitor speakers, etc.
PostPosted: Tue Aug 30, 2005 8:59 am
Oh, and use your current player in this setup, though for faster seek times and less skipping, you could upgrade to a professional player like the RSQ 333 later as well...
PostPosted: Tue Aug 30, 2005 1:51 pm
Thank you TopherM.  That is the idea I was thinking of.  The ability to upgrade as we go.
I am not sure I want to use this Fleco system as the player.  We have had problems with it pausing on it's own durring playback.  A major pain in the arse.
I think we will donate it to my wifes daycare.
Users browsing this forum: No registered users and 1464 guests
