[ 12 posts ] |
Matyu
Posted: Sun Aug 28, 2005 1:52 pm |
| newbie |
Joined: Sun Aug 28, 2005 1:43 pm Posts: 6 Been Liked: 0 time
I bought a microphone to play karaoke on my computer. It's a Sony F-V320.
When I plug it into my computer, it's working, but the sound is very low. In the volume comtrol, if I change the volume or put it to mute, nothing will happen. It will still work at a very low volume.
Is there a way to make the volume higher?
Thank you.
Jian
Posted: Sun Aug 28, 2005 3:08 pm |
Goto vol control, click option and tick advanced control. You will see an Advance button below the mic channel ,Press the buttom and a window will pop up and at the left bottom coner there is an option to mic bost; tick that. Good luck
Matyu
Posted: Sun Aug 28, 2005 3:36 pm |
| newbie |
yea I tried that too. It seems any parameters that I change in my volume settings doesn't affect my microphone at all, like my computer doesn't know that a mic is connected. Do I have to install plugins or something?
Jian
Posted: Sun Aug 28, 2005 3:52 pm |
check if you plugin your mic to mic in and not line in. Mic in is the green ring hole.
Matyu
Posted: Sun Aug 28, 2005 4:10 pm |
| newbie |
Yea I did :( maybe I need an amplifier or something...
Jian
Posted: Sun Aug 28, 2005 6:23 pm |
No you dont an an amp;you will blow your sound card.Signal from an amp goes to the speakes. Try and isolate the problem. To see if the problem is the sound card, use other mic and if it work then it may be the new mic thats the problem. Change cable too. Also see if the mic works on other system.
ps: I remember I had this problem before buy cant remember how it got solved.
Are you trying to listen to your self while singing or are you trying to record? Try opening a recording software and record you voice and see the recording vol. You should be able to record.I think some where is a control that is way down that prevent you from hearing yourself thru the speaker while you are singing or talking.
Matyu
Posted: Sun Aug 28, 2005 7:09 pm |
| newbie |
yea I can't record with it. It's like there's no mics plugged into the computer. But the strange thing is that I can hear my singing with it, but not loud enough for me. I just want to make it louder
Jian
Posted: Sun Aug 28, 2005 7:17 pm |
Are you sure the mic vol is up in the playback control. For recording make sure you tick the mic as yoiur recording input.
Matyu
Posted: Sun Aug 28, 2005 7:51 pm |
| newbie |
oh, I could record with it now. But the strange thing is that I can record when I select "stereo mix" or "Mono mix" to record. When I use "microphone", nothing happens.
My microphone is not reconised as a microphone. How can I change that?
Jian
Posted: Sun Aug 28, 2005 7:59 pm |
What sound card and recording software are u using? From where do you get the 'stereo mix and mono mix' thing?
Matyu
Posted: Mon Aug 29, 2005 5:56 am |
| newbie |
well, I fixed the problem now. I just plugged my mic at the wrong place. I feel so retarded now LOL
Jian
Posted: Mon Aug 29, 2005 2:58 pm |
Badsinger @ Mon Aug 29, 2005 7:52 am wrote: check if you plugin your mic to mic in and not line in. Mic in is the green ring hole.
Did I not ask you to check where the mic is plug in? Now let's hear you at SS.
[ 12 posts ] |
Users browsing this forum: No registered users and 1470 guests |
