KARAOKE SCENE MAGAZINE ONLINE! - Ripping Media Cloq Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Sun Nov 01, 2026 12:52 pm
 Post subject: Ripping Media Cloq
PostPosted: Mon May 23, 2005 3:41 pm
Sometimes it takes this old mind awhile to figure something out. Ive been ripping Sound Choice with cavs but always had problems with the last song track... Here is the way to do it with Cdrwin...
  From the initial menu select toc or the lower left box with the cd in. Make a note of the   Lba on each audio track or print out a copy.  Then under extraction dot select sectors put the Lba value for each track in the start box and the next track Lba -1 in the end box. Under data type select audio with cdg. Give a path and name to the track and then start Do the same with each audio track.. For the last audio track extract only about half of the first part of the sector. Convert it to audio and cdg Then play it back with winamp and check the end If it is too long decrease the number in the end box. An sc8862 winds up about 42%...
 Post subject: Re: Ripping Media Cloq
PostPosted: Tue May 24, 2005 3:31 am
I believe what you are refering to is Multisession...... not Mediaclog. Mediaclog is a totaly diffrent animal.
PostPosted: Tue May 24, 2005 9:52 am
MediaCloq discs were only SC series 8700-8735 if i'm not mistaken.  But these CAN be ripped with Tricerasoft.  It takes about 3-5 hours to completely finish the disc, but it does work.
PostPosted: Tue May 24, 2005 11:07 am
:O Ok i leaRned somethin' Again I guess I didnt get any of those. The last 2 or 3 years I have been getting Top Hits Monthly $60 - $80 month and shied away from Sc for that very reason.. (The old cowboy resists evry urge to jump on a soapbox and start preachin about the old days of buyng and selling horses and the ways of doin business. Smiles and puts the final period. and clicks submit)
PostPosted: Tue May 24, 2005 11:30 am
If you go to the http://forum.mtu.com/showthread.php?t=4238&page=1&pp=15and read the posts. it will tell you how to rip them amd make an unprotected disk
Chartbusters, soundchoice, top hits pop hits and more are starting to use this
PostPosted: Tue May 24, 2005 7:46 pm
Unfortunately, they allso did this with older, popular discs that they were repressing... such as a 70s & 80s discs, etc.
Users browsing this forum: No registered users and 1484 guests
