KARAOKE SCENE MAGAZINE ONLINE! - Can't get the vocals to record seperately in different track by themselves. Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Sun Nov 01, 2026 3:23 am
PostPosted: Fri May 06, 2005 10:23 am
OK guys here is the problem, when i first started recording i didn't have this prob so i don't know where it came from. when i try to record i import a mp3 file to use as my backup right, then i click on the record tab for the next track to record my vocals, but when i go to editting screen the music is recorded with my vocals so i can't change the volume or anything , it would just mess up. how do i get my proggy or whatever to just record my vocals only on a seperate track? like i said i could do this no problem when i first started doing it, but now it won't record without the music as well.  :(
I'm in my own little world,but it's ok they know me here.
http://www.myspace.com/faile_x2
PostPosted: Fri May 06, 2005 7:52 pm
You did not say what recording software you are using; that will help a lot in answering your question.
But it look like you are recording on 'what u hear' and not on mic.Try going to your soundcard controler and change that seting. If you are using onboard soundcard the rightclick the vol control at the rightbottom of your screen. If you use sbl go to mixer
PostPosted: Sat May 07, 2005 4:47 am
ok, i am using cool edit for the most part, but it doesn't seem to matter what proggy i am using i tried it with audacity as well, same problem, how do i change these settings, because i've gone in and tried to change a few things and nothing seems to work. help!! please lol.i am blond lol, so i need specific instructions lol.
thanks a bunch.
PostPosted: Sat May 07, 2005 7:19 am
If I read you right the problem seem to be soundcard related. Change your recording setting to mic. To do this; go to> start> program>accessories>entertenment>vol control and select mic. If you do not see mic in one of the option, move your curser to the top and clik option>properties>adjust vol for> dot the recording option and it will bring up and other window after you press ok. Tick the mic option.
If you have SBL as your soundcard goto mixer and at the[highlight=red] rec[/highlight] penal click the pulldown symbol( a triangle that point downward) and choose mic.
I hope this help.
PostPosted: Sat May 07, 2005 7:43 am
ok then i've got a problem i've tried this and still have probs, is there anyway i can go back to default so i can start over again lol? hehe maybe if it's back to default settings i can start ver from scratch, and try this again cause nothing i do seems to wanna work for me. :(
PostPosted: Sat May 07, 2005 7:18 pm
what soundcard do you have? This seem like a soundcard setting to 'what u hear' for recording when it should be 'mic' ;and not recording software related. And am not sure if  default is for mic.Most soundcards will have more than one source of recording imput ie mic, wav., midi, etc so its up to you to choose which one you are using.
Are you sure that you follow the steps above? pm me if you still have prob.
Users browsing this forum: No registered users and 3328 guests
