Cable Question
https://ksmo.us/forums/viewtopic.php?f=1&t=4743
Author:  jamkaraoke [ Fri May 06, 2005 5:19 am ]
Post subject:  Cable Question
I go into the local music store to buy some cables to replace (upgrade)  my existing ones.  Speaker Cable --No problem  - Microphone Cables again self explanatory.
But now I need a 1/4" - XLRF  to hook up from the amp to the Mixer ?  All I see are microphone cables?  I also want to replace my 1/4"-1/4" cables that connect my maximizer or other processors to one another.
I see INSTRUMENT CABLES  and SPEAKER CABLES and PATCH CORDS ETC ETC.
Are they all the same?  Can a microphone cable be used to connect your mixer and AMP?  CAN a instrument cable be used to connect various equipment together?
or is shorter "speaker" cables the one to be used ????
Whats in your RACK?
Author:  EElvis [ Fri May 06, 2005 6:31 am ]
Post subject:  Re: Cable Question
For interconnect cables in the low level signal path, I use either xlr where I can and 1/4" trs in other cases. But all of my equipment supports this.
Author:  pkircher [ Fri May 06, 2005 6:38 am ]
Microphone cable and XLR cables are the same thing, for connecting your maximizer and other equiptment use patch cables preferably TRS balanced cables assuming your equiptment supports this.
