KARAOKE SCENE MAGAZINE ONLINE! - Good mixer for home use? Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Sun Nov 01, 2026 1:43 am
 Post subject: Good mixer for home use?
PostPosted: Sat Apr 23, 2005 7:03 am
Hey all, i'm looking for a microphone mixer to use at home for karaoke. here's what i would like:
- at least 3 mic inputs
- reverb/echo or something
- around 100 dollars
Output will be going into my home stereo system (i know i should use live speakers, but I wont be doing anything crazy here)
Any suggestions? Not looking for anything too amazing here....mainly want to get rid of the .15 secondish delay on the mics the way i have them set up now (going through an xbox).
I see these little mixers that look about the size of a deck of cards and wonder if those would suffice, then i see powered mixers that are laptop sized and wonder if thats what i need. don't really know what advantage/disadvantage there is to a powered or unpowered mixer.
Thanks for any help!    :D
PostPosted: Sat Apr 23, 2005 7:21 am
It only has 2 mic inputs, but everything else fits your criteria.
http://www.musiciansfriend.com/srs7/g=l ... id/630156/
Powered vs unpowered.  Powered mixer means it contains the power amp to run the speakers all in 1 unit.  Non powered means you need an external amp source (which your stereo will essentially be).
PostPosted: Sat Apr 23, 2005 5:45 pm
Hey, that one looks pretty nice.  Question, if i wanted to use more than two mics, why cant i just plug it into one of the other inputs?  (using the 1/4" plugs)
I also found this one that i can get at a local shop for about 40 bucks...doesnt have any effects, but i could just get an external thingamijig at some point, right?
http://www.musiciansfriend.com/srs7/g=l ... _id/129692
Users browsing this forum: No registered users and 2542 guests
