| Need help! not sure where this stuff goes. https://ksmo.us/forums/viewtopic.php?f=1&t=4521 |
| Author: | Jason Steel [ Sat Mar 26, 2005 8:14 am ] |
| Post subject: | Need help! not sure where this stuff goes. |
Hi, I need help on where to hook up my equipment. (what order the equipment goes) I have mixer (has inserts) sonic maximizer 31 band eq feedback destroyer I am not sure the order in which they need to be hooked up for best sound. |
| Author: | Lonman [ Sat Mar 26, 2005 12:49 pm ] |
| Post subject: | Re: Need help! not sure where this stuff goes. |
I would run the mixer to the eq, eq to the amp. Run the Sonic Maximizer in the "main" inserts on the mixer. If it doesn't have main inserts, the run it inline after the eq & before the amp. Drop the Feedback destroyer (don't need it with properly set-up eq, speaker placement & gain structure) - but if you must have it, put it after all the eq's & before the amp. |
| Author: | Jason Steel [ Sat Mar 26, 2005 4:00 pm ] |
I have inserts, one for each mic is this where to put the Sonic max? I don't see a main one. |
| Author: | Lonman [ Sat Mar 26, 2005 5:34 pm ] |
Jason Steel @ Sat Mar 26, 2005 4:00 pm wrote: I have inserts, one for each mic is this where to put the Sonic max? I don't see a main one.
You could put it on the mics only if that's what you would like. It will give you a little extra control for them, but it is more effective on the overall mix. So run the mixer to the eq, eq to the Sonic Maximizer then to the amp. |
| Author: | Jason Steel [ Sun Mar 27, 2005 12:19 am ] |
Lonman, Thanks for the help again.
| Author: | pkircher [ Sun Mar 27, 2005 9:16 am ] |
Actually I find that the sonic maximizer is better in front of the eq. Once you hook up the sonic maximizer, set the eq flat, set the maximizer so that it sounds good, and you may not even need the eq but if you do you can do some tweaking from there. At Least that's how I do it when I setting up a room and normally I would defer to lonmans superior experience but give it a try this way too. I have a small rig that I don't even use an eq at all with anymore just BBE. |
