KARAOKE SCENE MAGAZINE ONLINE! - Wireless Microphones for Karaoke Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Sun Nov 01, 2026 3:23 am
Post new topic Reply to topic  [ 30 posts ]  Go to page 1, 2  Next
PostPosted: Thu Mar 03, 2005 12:43 pm
Hello folks!
What is a good (not too expensive $100-$200) Wireless Microphone for Karaoke?
I want to get some for shows, but since people don't treat them well, I don't want to buy very expensive ones.  But I do need them to be reliable.
Any experiences with Wireless Microphones?
Thanks!
PostPosted: Thu Mar 03, 2005 4:32 pm
Knightshow has recommended a VHF setup from Radio Shack and has had good luck with it.  He'll have to post more information about it though as I have no experience with the product.
I've also heard good things about the VocoPro UHF 3800 rack mount microphones which can be had for about $250 for a pair.  From what I've heard it's the only decent product Voco has made....  There's a guy here on the board that's been using them for 6 months and has had no problems.  His testimonial has been so strong that I'm considering picking up a set myself.
In that price range though you won't be getting into Shure, Sennheiser, and the like though...
PostPosted: Thu Mar 03, 2005 6:05 pm
go to radioshack.com and look at their wireless microphones.
it's a good, solid mic, but as meister has said, you get what you pay for.
also, karaoke.com has a set of the new AS990s that's dual wireless... and they come highly recommended.
PostPosted: Fri Mar 04, 2005 6:41 am
kjbill, I understand wanting to go cheap, but try to avoid junk. First of all, I strongly recommend AGAINST any VHF system. KJ's don't loose mic's on a daily basis, so don't be too concerned about that, but loosing clientele due to crappy mics happens often. At least when you buy mics, avoid radioshack and buy UHF. Search for Nady mics as well. I have their UHF systems, and am very happy with them.
PostPosted: Fri Mar 04, 2005 9:46 am
Thanks Tony!
I've had that microphone for over two years, and never had a problem with it!
While I admit the UHF is better than the VHF, the mic is NOT junk.  It's an Audio-Technica... here's the specs...
PostPosted: Fri Mar 04, 2005 9:50 am
No, no Matt, I didn't mean to say you had a junk mic, as a matter of fact, I didn't know what mic you had. The point I was making is not to buy junk. We both know that there's a lot of junk mic's out there, and radioshack is well know that MOST of their mics are horrible.
PostPosted: Fri Mar 04, 2005 11:27 am
actually, the other two mics I use are both bought from Radio Shack.
Their grey model:
and their SHURE mic ( I believe it's comparable to the SM or PG58)
PostPosted: Fri Mar 04, 2005 5:09 pm
Matt, the second mic you show shure looks like my PG58 (pun intended).
I wouldn agree that it's always an investment and investing in good equipment is usually a pretty smart thing to do. The problem is if you have drunk clientle dropping them.  There are some less expensive options out there than the $500+ Shure SM58 or Beta58 Wireless
Shop around and look for a system with a mic that's built sturdily, and has options on the freq's it works on.  Since the mic Matt mentioned works in the higher part of the VHF band and two other bands outside of the 'normal' VHF frequencies he's likely not having a problem.  Be sure whatever you purchse you can take back if there is a problem with reception.  Note that some online retailers will NOT take back any mic.
PostPosted: Mon Mar 07, 2005 1:55 pm
Thanks folks!
I ended up going with the:
Audio-Technica DR-2600 UHF Hand-Held Wireless System
http://www.musiciansfriend.com/srs7/sea ... pid/270437?
Cheers!
PostPosted: Tue Mar 08, 2005 8:04 am
I agree with Allstar  and own a few NADY UHF wireless mic's they are inexpencive and great sounding. I bought dual VHF mic's on Ebay and when I hooked em up got bad interference from my lap top  due to VHF so I gave them away. My $170.00 learning expierence.
I love My NADY'S I bought them from Karaoke.com as thats where I buy alot of stuff.
the customer service is great there. I bought three disc packs in one day using 2 diff credit cards....the next Day I got a call (sunday morning at 10:00) it was the owner of Karaoke.com making sure it was me who was buying over $200.00 in disc's on two of my cards......protecting me from CC Fraud...Dam good customer service.
Michael
PostPosted: Wed Mar 09, 2005 6:27 am
FYI
The radio shack uhf wireless is an Audio Technica. The mics, and recievers are actually very durable, and have good audio. If you have a failure because of dropage, look at the wire going from the transmitter to the mic element. They will break upon impact, and a little soldier will cure it most of the time.
The Other mic's from radio shack are made by shure. and repackaged.
All in all a good value :hi5:
PostPosted: Fri Mar 11, 2005 12:11 pm
Been Liked: 11 times
I have two Nady systems I use for guitar.  If the microphone system is anything like the quality of the system I have, I might suggest Nady is lacking.  One system is the 441 (gold) system, the other is true-diversity (whatever that is supposed to mean, unidirectional?), and abit better, yet still cuts out even when I'm within close proximity of the unit.
I recall hearing at one point, (this goes back aways) the Realistic microphones were made by Shure, The realistic upper end microphone was the Shure SM-58, yet about 20 dollars less.
PostPosted: Fri Mar 11, 2005 12:14 pm
How does the PG-58 differ from the SM-48 and 58 ?  IS the PG model less sensitive ?
That model must be a relatively new model
PostPosted: Fri Mar 11, 2005 2:05 pm
I bought the Gemini UX-1620M, which come as a pair and it is a UHF system at the recommendation of someone in this forum. The set came out to about $169.00 and they have worked well. The only "problem", which was mentioned in the review is that they are a little sensitive to people tapping on them while singing, other than that... they are great!
Frank
Pelican in Flight KJ/DJ
Miami, Florida
PostPosted: Mon Mar 14, 2005 6:59 am
In the late 70's when I managed a Radio Shack store, all of their mic's were Shure's, with the Radio Shack name on them.  Back then, smart musicians knew they could buy a SM58 with the Radio Shack name on it for about 1/2 the price. Now days it looks like they're selling more and more items without re-naming them.  You can buy a Shure mic as such.  I believe their wireless mics are Audio Technics.
    Now as to what I use,  I bought an inexpensive(less than $100) Nady VHF just to try out a wireless system.  Most customers liked it, (not everyone gives a s##t what they're singing into), and a few really liked being able to walk around the bar while singing. I had a little interference with some neon lights and a dimmer switch, only if someone was wondering around with the mic and got near one of the lights.  Satisfied with the results I bought another Nady, only UHF.  IMHO they both sound great, and I can buy 3 or 4 of them, if they get broken, for the price of 1 Shure.  Set up is also much easier with the wireless, as I'm not running mic wires all over the place.  Something else that amazed me is the feedback rejection, I realize that gain settings have a lot to do with this, but they must have a great polar pattern, cause unless you point them directly at the speakers, I've had no problems ( this may be a good quality for those who don't use monitors, and singers stand next to , or in front of the main speakers).
"Either write something worth reading or do something worth writing about."
Benjamin Franklin
PostPosted: Fri Mar 18, 2005 2:40 pm
For lower end mics, the Nady's are acceptable to most people singing into them. However if its in your budget spend a couple hundred more and pick up a shure. There UHF sm58's arent that expensive. Youll appriciate the diffrence in quality for sure.  I used to have 2 nady's for the drunk people at the shows and they just kept on breaking. The 2 vhf sm 58's have taken their place, and I bout a beta 58 uhf for just under 500. now thats heaven lol.
Dangerous
[url]seventhds.com[/url]
PostPosted: Fri Apr 01, 2005 8:23 am
Just bought the AS990s on sale at karaoke.com.
I have their predecessor the 880s, and thought that they were okay. MAN, what a difference a generation makes.
The mics have a better battery area, low battery indicator, two switches rather than one (one's a mute the other's the on/off - that COULD be a problem with switch happy people ! ! !), the feel of the mics is incredible. Also, the receiver end has twist on antenna connections!, and the mic volume dials are much more professional... not knobs to twist, but rather, a thumb swivel (the way my Boss BR1180 cd recorder turner is)... I'm REALLY excited about this mic, and will probably get another very soon!
PostPosted: Fri Apr 01, 2005 9:54 am
Now Ya'll got me thinking about wireless mics again I use one for the announce mic but use shure for the singers.  Good thread...
 I get a kick out of watching the singers on the today show  the younguns use the wireless  oldtimers still have their old 58..  They had jimmy buffet on one morning on a beach.. He had duct tape wrapped around the mic cord and mic....It was absolutely hilarious he was too busy jammin to sweat the small stuff LMAO
PostPosted: Fri Apr 01, 2005 10:47 am
The thing about the younguns is that they don't play instruments & have to dance to have anyone really pay attention to them - most of them aren't singers (but that's beside the point) - so they can't have a handicap of a wire possibly tripping them up.  The oldtimers (at least a good majority of them) play instruments & it really doesn't matter if the mics are wired or not, they pretty much stay in one spot, but then the music & singing is so good, they don't really need to dance around.  Some do wear a wireless headset on occasion.
PostPosted: Fri Apr 01, 2005 5:45 pm
Their grey model:
I had the grey model - got rid of it the moment I bought a Shure SP-58 - good for voice over - not good for dynamic performers or those with poor voice control that can project.
Despite the internet rumor, Karaoke is not Japanese for "drunk buffoon with microphone."  However, "rotation," is Japanese for wait your damn turn!
Users browsing this forum: No registered users and 3324 guests
