[ 14 posts ] |
kaka
Posted: Mon Apr 08, 2019 12:44 am |
Joined: Fri Apr 05, 2019 1:12 am Posts: 1 Been Liked: 0 time
To get the sound from our laptops to our speakers goes through a chain of devices each having their own level/volume controls. For example, there's my laptop, Lexicon Alpha USB Audio Interface, stereo output on my mixer, amp or powered speakers, etc.
Are you guys (and gals) maxing them out and controlling everything with your mixers? So, here are some questions:
Laptops - I have mine set at 80%. Should it be set at 100%? Lexicon Alpha - I have mine set at the 1 o'clock position. Should it be fully clockwise? Powered Amp (when I use passive speakers) - I have this fully maxed clockwise. Powered Speakers - Using the 12 o'clock position right now.
I have thought about this and the right way to do this and I think we may have touched on this before but I want to see what you all use. Is it better to set volume levels for all devices on full (Unity Gain) and control everything with your mixer? How do you determine the best settings for each device?
Elementary Penguin
Posted: Fri Apr 12, 2019 12:37 am |
| Advanced Poster |
Joined: Wed Jan 07, 2015 12:54 am Posts: 339 Been Liked: 130 times
Nobody? Okay then, but I'm not the techie expert around here, but anyway...
Computer volume on max, Lexicon set at 12:00 (or 1:00 when the bar is really packed and noisy) and the computer's channel on the mixer at zero, give or take for each track. By zero I mean the zero setting printed next to the slider, about 3/4's of the way up.
The amp should be as high as you can get it without seeing any red -- red means sound distortion, so back off. That's generally around 1:00 or 2:00, but varies a whole lot depending on what amp and what speakers, so just keep an eye out for that red peak indicator.
Posted: Fri Apr 12, 2019 1:34 am |
kaka wrote: Laptops - I have mine set at 80%. Should it be set at 100%? I have my laptop volume at 100% Quote: Lexicon Alpha - I have mine set at the 1 o'clock position. Should it be fully clockwise? 12 oclock Quote: Powered Amp (when I use passive speakers) - I have this fully maxed clockwise. If only using the 1 amp, then yes, wide open. If using multiple amps (bi/tri or more amp system) then each amp will be adjusted accordingly. Quote: Powered Speakers - Using the 12 o'clock position right now. About right, more if needed - since it's considered 'the amp'. You are controlling overall volume from the mixer.
Alan B
Posted: Fri Apr 12, 2019 12:49 pm |
My settings are similar to what's been posted...
Laptop..................85% Lexicon Alpha........1'O Clock Powered Speaker...12'O Clock Mixer Input channels (music from laptop) 12'O Clock Mixer Master Channel..."0"
Everything (mics and music) is then adjusted by the mixers sliders.
_________________ Electro-Voice Evolve 50... Taking Sound To The Next Level.
Posted: Fri Apr 12, 2019 5:26 pm |
Joined: Sun Nov 01, 2009 4:50 pm Posts: 909 Location: Cape Breton, Nova Scotia, Canada Been Liked: 450 times
I've always understood that the laptop's volume control should normally be set at 50%. Otherwise those noted above seem right to me.
_________________ Earl
Posted: Sun Apr 14, 2019 5:37 pm |
Earl wrote: I've always understood that the laptop's volume control should normally be set at 50%. Otherwise those noted above seem right to me. I've always set mine wide open. But I also use an external card. Built in cards sound like crap at any volume IMO.
Posted: Mon Apr 15, 2019 6:03 am |
Lonman wrote: Earl wrote: I've always understood that the laptop's volume control should normally be set at 50%. Otherwise those noted above seem right to me. I've always set mine wide open. But I also use an external card. Built in cards sound like crap at any volume IMO. I use a Lexicon Alpha also, but still set the laptop at 50%, and it seems to work fine for me... so now I'm assuming it may not really make a difference. I wonder what, if any, technical differences there might be.
DannyG2006
Posted: Mon Apr 15, 2019 10:04 am |
Earl wrote: Lonman wrote: Earl wrote: I've always understood that the laptop's volume control should normally be set at 50%. Otherwise those noted above seem right to me. I've always set mine wide open. But I also use an external card. Built in cards sound like crap at any volume IMO. I use a Lexicon Alpha also, but still set the laptop at 50%, and it seems to work fine for me... so now I'm assuming it may not really make a difference. I wonder what, if any, technical differences there might be. 50% is way too low unless you are running the main volume of the mixer and the speakers or amp at 100%. Unless you have perfect placement of the the speakers you run the risk of feedback.
MrBoo
Posted: Mon Apr 15, 2019 10:51 am |
Joined: Tue Jul 31, 2012 3:35 am Posts: 1945 Been Liked: 427 times
DannyG2006 wrote: 50% is way too low unless you are running the main volume of the mixer and the speakers or amp at 100%. Unless you have perfect placement of the the speakers you run the risk of feedback. Feedback? From a music source?  . That's some miced up stuff there!
Alan B
Posted: Mon Apr 15, 2019 10:56 am |
MrBoo wrote: DannyG2006 wrote: 50% is way too low unless you are running the main volume of the mixer and the speakers or amp at 100%. Unless you have perfect placement of the the speakers you run the risk of feedback. Feedback? From a music source?  . That's some miced up stuff there!
mrmarog
Posted: Mon Apr 15, 2019 11:07 am |
Alan B wrote: MrBoo wrote: DannyG2006 wrote: 50% is way too low unless you are running the main volume of the mixer and the speakers or amp at 100%. Unless you have perfect placement of the the speakers you run the risk of feedback. Feedback? From a music source?  . That's some mixed up stuff there!
Paradigm Karaoke
Posted: Tue Apr 16, 2019 12:26 pm |
Joined: Thu Aug 12, 2010 6:24 pm Posts: 5108 Location: Phoenix Az Been Liked: 1280 times
mrmarog wrote: Alan B wrote: MrBoo wrote: DannyG2006 wrote: 50% is way too low unless you are running the main volume of the mixer and the speakers or amp at 100%. Unless you have perfect placement of the the speakers you run the risk of feedback. Feedback? From a music source?  . That's some mixed up stuff there!
Alan B
Posted: Tue Apr 16, 2019 7:22 pm |
Karaokedude69
Posted: Mon Apr 22, 2019 10:14 pm |
Joined: Wed Aug 17, 2016 8:08 pm Posts: 65 Been Liked: 7 times
So many opinions.. Which is exactly why you go to some shows where the sound is off the chain perfect and others where the sound is absolutely horrible. I promise you that some of those on here giving advice can not run sound to save their a$$ but believe they are the best while others commenting here have their sound on the money.. It really just depends on your hardware. Each laptop sports a different brand of internal sound card and they are not all the same. Same goes with external sound cards. Truth is, if you have a good ear, just tweak your settings and get a sound that is right for you and that your singers like. There is no one size fits all recipe.
_________________ A fool thinks himself to be wise, but a wise man knows himself to be a fool. "William Shakespeare"
[ 14 posts ] |
Users browsing this forum: No registered users and 2657 guests |
