KARAOKE SCENE MAGAZINE ONLINE! - Looking For New Computer To Run Karma Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Sun Oct 25, 2026 7:18 pm
PostPosted: Sat Aug 05, 2017 7:52 am
Been Liked: 12 times
Hi Guys, looking for a new computer to run Karma with no glitches, any recommendations? I've had issues with Windows 8/8.1 off a Dell top of the line, maybe it's the computer, hard to diagnose, the program winds up getting stuck in play. Anyway I haven't been able to diagnose or fix the issue so I'm in the market for a new one. Just throwing it out there to see if anyone is using something with no issues, thanks. Capt Frank
PostPosted: Sat Aug 05, 2017 10:18 am
Post the specs of the one you have freezing..
:angel:
PostPosted: Sat Aug 05, 2017 2:29 pm
Been Liked: 259 times
Turn off graphics hardware acceleration and try running Karma. . . it's one of the most common problems for many audio-video problems in a variety of programs.
To disable graphics hardware acceleration:
Choose Start > Control Panel.
Double-click Display.
Click the Settings tab.
Click Advanced.
Click the Troubleshoot tab.
Move the Hardware Acceleration slider to None.
Click Apply and then click OK to accept the new setting and close the dialog box.
PostPosted: Sat Aug 05, 2017 7:31 pm
There is NO PC/Laptop available anywhere in the world to run Karma. It's gonna crash regardless of specs.
PostPosted: Sun Aug 06, 2017 4:10 am
I guess you have not read any of my posts about how many years I have run Karma on a super slow 9 year old AMD Toshiba laptop without any crash or flaw of any kind. I have found something that works and I'm sticking with it. Karma 2014.9.1 and a stripped down XP Pro 32 bit with only 17 services running.
I am not on a constant quest for the latest and greatest. My goal is to make my show flawless, efficient and fun. An always changing show is not a way to build a strong following. You have a constantly changing customer base so no one ever gets accustomed to your method. I would bet that if you had a normal venue you would see what I am talking about.
PostPosted: Sun Aug 06, 2017 5:33 am
Actually I also have an older Acer windows 7 machine using the old Karma program I received from around 2007 and it runs without a glitch. Isn't it sad that a high end machine like the Dell cannot run the latest Karma software without freezing?
PostPosted: Sun Aug 06, 2017 5:51 am
:angel:
Dell Inspiron 15R, Windows 10, Core i7-3537U@2.00 GHz, 8 GB Ram, 64 bit Operating system, x64 - based processor
PostPosted: Sun Aug 06, 2017 5:59 am
Click Advanced.
There is no troubleshoot tab on advanced display settings in Windows 10
PostPosted: Sun Aug 06, 2017 7:14 am
Capt Frank wrote:
:angel:
Capt Frank, your new machine has enough horsepower to run almost any program... let alone Karma. Something else is the problem. Have you tried a clean reinstall and eliminate all "bloatware", disable all start programs, ditch any anti-virus, disable indexing, unzip karaoke files, reduce second monitor resolution, disable unneeded services, and defrag. Store your files on an internal drive and not an external USB drive
Zip files create fragments everytime a file is unzipped, because the zip is open temporarily, played, and then discarded.
Users browsing this forum: No registered users and 3259 guests
