[ 17 posts ] |
Spankie The Wizard
Posted: Thu Dec 23, 2004 12:25 pm |
Joined: Fri Dec 17, 2004 7:44 am Posts: 44 Location: Pensacola, Florida Been Liked: 0 time
Did you get my message? About what the heck to do with my Macintosh?
I figured sending a PM was the best way to contact you. I am prolly just asking a all around easy question.. I just want to know what wires I need to hook up from my Craig Karoake Machine Output to my tiny lil line in input on my Mac. Powerbook so I can record. I heard you were the Mac person I needed to talk to. I am about to go out shopping and I was going to pick up what I needed while I was out. I wish somebody would tell me so I can go buy what I need!
_________________ Keep Moving, Don't Be A Target!
Gilly
Posted: Thu Dec 23, 2004 12:29 pm |
Joined: Wed Mar 17, 2004 8:16 am Posts: 1234 Location: British Columbia Been Liked: 23 times
So, for sure, do you HAVE a mic jack on your computer? because, if you do NOT, then, there is no point. (for example, i don't have one on my ibook)...
That is simply a standard audio jack. What do the connectors LOOK like, on the back of your karaoke machine. Are there two, one red and one white, side my side, (i believe, rca connectors?)? Are they the tabs, taht you stick wires in to pinch them?Are they little clips, to stick bare wire in?
Describe, in more detail.
Spankie The Wizard
Posted: Thu Dec 23, 2004 12:37 pm |
Gilly wrote: So, for sure, do you HAVE a mic jack on your computer? because, if you do NOT, then, there is no point. (for example, i don't have one on my ibook)...
Okay.. ignore my PM.. lets just do this here.
I have on the back of the Karoake machine three outputs
a red marked with a "V" a white marked with an "R" and another red with a "L" prolly RCA... but the wires that come with the machine do not fit in the Input of the computer, it is too big.
I do have mic imput so that is cool.
Gilly
Posted: Thu Dec 23, 2004 12:44 pm |
Again....
Will a standard headphone plug fit into your mic jack??!?!?!?! LIke, the really CHEAPO standard buy anywhere pair of headphones.. a computer set of headphones.
If SOOO , continue reading.. ASSUMING they do, as i have NEVER seen anything else EVER as the audio input on a computer...
By the way, v, is video, L is left speaker, and R is right.......obviously...
If it does, then you simply need a cable with two rca connectors at ONE end (one red, one white), and then a standard audio jack a the other end. Now, match up the plugs. L- is for left, and that is white, and R right, and that is the red one.
Then, plug the other end into your line in on your power book.
You will also need to make sure that the connectors (the red and white ones) and both male. If you can only get the female end, that you will need a male to female adapter as well.
Spankie The Wizard
Posted: Thu Dec 23, 2004 12:47 pm |
That i have a set of earphones sitting right here next to me.. and yes they fit.. and you answered my question... most excellent.
Now.. I shall shop
Spankie The Wizard
Posted: Thu Dec 23, 2004 12:52 pm |
is there an adapter that will make my regular mic fit the audio input holey thingy on the computer??? Does it have a name that I can ask for when I go to the radio shack & reveal my blonde tendencies to the pimple faced 18 year old sales staff in the store?
Gilly
Posted: Thu Dec 23, 2004 12:57 pm |
A regular mic doesn't work in a mac, unless you buy a usb mic... however, a regular mic WILL work, if you like, SCREAM in, and turn up the volume and gain...but, that won't work to record, eh?
There are SOME regular mics you can use, as long as they are amplified mics....
Are ya following me here?
Spankie The Wizard
Posted: Thu Dec 23, 2004 1:00 pm |
Hmmm... I would think that there would be an adapter of sorts... usb huh?
well a girls gotta do .....
You have been so much help
I'm reeely not a retard.. just out of my juristiction ya know.
Now.. if you want graphix baby.... I'm da one!
Gilly
Posted: Thu Dec 23, 2004 1:04 pm |
BY the way..  , you can actually buy that SAME cable at most dollar stores.... so, happy hunting:)
Spankie The Wizard
Posted: Thu Dec 23, 2004 1:05 pm |
Spankie you very much
karaokemeister
Posted: Thu Dec 23, 2004 2:50 pm |
iMic USB audio interface is what you're looking for. They are typically about $40.
You can check and see if one of the Soundblaster external devices (Extigy, Audigy NX2, MP3) will work as well (check the boxes for the mac to be listed as supported hardware).
karaokemeister
Spankie The Wizard
Posted: Thu Dec 23, 2004 8:20 pm |
I got the wires to hook my Karaoke machine to my mac. , and realize why am I doing this? If I have to add my vocals seperately after the music is recorded what is the point. I can just record the music off the freakin CD+G and then get a mic that will work with my macintosh.
When I started this endeavor I was under the impression that my voice, coming through the speakers in my Karaoke machine was availiable to the output on the Karaoke device and would be transferred to the "line in" audio input on my computer. Unless I am doing something wrong this must not be the case. The mic goes straight to the speakers.. huh?
If that is the situation then I guess I don't need to even bother with the Karaoke machine at all. Just pop the CD+G in a import the track into Audacity.
Then I guess you just blend two tracks right?
Let me know if I am missing something. I have read quite a few threads that talk about connecting to the Karaoke player for recording, so their must be a reason. Maybe I just don't have the array of components most of you are working with.
Man.. this stuff is totally fun.. I can waste a whole century just trying to figure silly crap like this out.
Melly
Posted: Thu Dec 23, 2004 9:57 pm |
Joined: Wed Jun 02, 2004 12:37 am Posts: 1376 Location: COLORADO Been Liked: 0 time
Spankie The Wizard
Posted: Fri Dec 24, 2004 9:03 am |
I don't know why I don't pick up the mic through the line in. I would love to get to the mixing part. I will keep searching.
Melly
Posted: Fri Dec 24, 2004 11:22 am |
Hmm, do you have a place on your Imac where it shows you to turn up the volume for your Imac? On mine, i have to go thru the windows volume control. I open it up...and it shows the different things.....like mic, wave, line in.....etc...i would pic MIC if i am using my pc mic....or line in if i am recording straight from the karaoke Machine. Also, what software do you have to record? You can do it thru there....if you have CEP or Adobe......go up to OPTIONS in the MUlit-Track.....and look for MIXER....click on that......and check LINE IN, or MIC.....i wish i could help more.
Spankie The Wizard
Posted: Fri Dec 24, 2004 1:33 pm |
BAM!...
I did it... I pulled out my daughters lil old cheepo Karaoke machine. It's an all in one kinda deal. and BAM! it worked.. perfectly... I get the mic and full control over the microphones' volume and reverb.. I am going to post a song or two in just a few.. unless I run into more probs in uploading the file.. but Spankie is a happy camper ... laa llaaa
[ 17 posts ] |
Users browsing this forum: No registered users and 3086 guests |
