southernsounds4u
Posted: Thu Sep 01, 2016 7:41 am |
Joined: Tue Nov 03, 2015 5:46 am Posts: 118 Images: 19 Been Liked: 32 times
If you're a mobil KJ , how do you set your table up and hide wires etc ?
Pics please, I started using an American Flag around the base of mine, but don't have a box made for containment on table top
_________________ I only do private parties, and you're not invited
mightywiz
Posted: Thu Sep 01, 2016 12:54 pm |
Joined: Thu Jul 07, 2011 12:35 pm Posts: 1351 Images: 1 Location: Idaho Been Liked: 180 times
i actually had a banner made at:
bannersonthecheap.com for $19 and a little shipping
I got a 6ft x 2ft banner that is attached to my folding table to hide wires and stuff
you have to do all the artwork yourself in vector graphic format and then do the text layout and build it all on their website and submit it. they will personally call you back if they have any issues with the print quality before they print it.
_________________ It's all good!
Kirks Karaoke
Posted: Thu Sep 01, 2016 5:47 pm |
Joined: Sun Feb 03, 2013 12:39 pm Posts: 735 Been Liked: 99 times
Just a black table cloth over a 2' X 4' table(mine). All the way to the floor.
bazinga
Posted: Thu Sep 01, 2016 6:04 pm |
Joined: Tue May 17, 2016 11:58 pm Posts: 266 Been Liked: 116 times
Kirks Karaoke wrote: Just a black table cloth over a 2' X 4' table(mine). All the way to the floor. Same here!
southernsounds4u
Posted: Fri Sep 02, 2016 7:25 am |
I've been using a 3x5 American flag attached to my table, what about boxes made to leave your equipment set up on the table ? do any of you have those ?
southernsounds4u
Posted: Fri Sep 02, 2016 7:27 am |
c. staley wrote:  Most facilities provide a table that I don't use.  You have your lights mounted on your speaker stands ? What kind are they if you don't mind saying, looks good
Smoothedge69
Posted: Mon Sep 05, 2016 8:10 pm |
Joined: Sun Dec 19, 2004 2:55 am Posts: 3885 Images: 0 Been Liked: 397 times
I have a white, 6ft folding table. I cover it with a black or blue cloth. I drilled three holes along the outside edge of the table, and cut matching holes in my table cloths. I hot glued plastic grommets in those holes. All my wires run into those holes, so they are all hidden. That way, everything stays neat.
_________________ I am the ONLY SANE 1 HERE
mrmarog
Posted: Tue Sep 06, 2016 5:48 am |
c. staley
Posted: Tue Sep 06, 2016 1:43 pm |
| Extreme Poster |
Joined: Thu Jun 06, 2002 7:26 am Posts: 4839 Location: In your head rent-free Been Liked: 583 times
southernsounds4u wrote: You have your lights mounted on your speaker stands ? What kind are they if you don't mind saying, looks good Yeah, I clamp them directly to the speaker stands. Most of the time, I don't use dedicated light stands -- it's just more to carry around. And it certainly makes it easier for the lights to "hear the music" when you have them set to activate with an audio trigger. The lights themselves are nothing special, but I have been good about using physically small lights that put out a LOT of light effects.
screamersusa
Posted: Thu Sep 08, 2016 11:07 pm |
Joined: Tue May 20, 2014 8:49 pm Posts: 300 Been Liked: 50 times
Some cabs like my PV's have flying points on top. I have a bar that holds 3 lights that I simply screw on top of each cab with thumbscrews. Unfortunately I have a rack with a yamaha mixer and comps in that I put in a server rack (X shaped portable stand for big restaurant server trays). The table gets a black cloth. Still working it all out. I'm playing with hotspots mounted on the speaker poles as side fills. I use a guitar amp stand with a modded tv mount to slide the 34 inch tv on to at an angle and a floor monitor under it. Keeps the singer able to face forward and glance down a little to pick up the lyrics and interact with the crowd.
MrMamrog....Sweet little setup ya got there!!!
_________________ Purple Frog Karaoke Cuz we all feel odd and love to "croak"
Paradigm Karaoke
Posted: Thu Sep 08, 2016 11:14 pm |
Joined: Thu Aug 12, 2010 6:24 pm Posts: 5108 Location: Phoenix Az Been Liked: 1280 times
mrmarog, are those plastic shelves that you painted black?
mrmarog
Posted: Fri Sep 09, 2016 6:37 am |
Paradigm Karaoke wrote: mrmarog, are those plastic shelves that you painted black? I purchased them from Home Depot about 8 years ago. They are black plastic. Home Depot shelves are now gray or tan. I also found a folding table and removed the laminate surface from it and attached it to the plastic shelving. The back rest is made from the spare legs with 1 inch pvc inside it for reinforcement. I used a 1 1/8 hole saw and made several holes in the channels of the shelving and routed my wires through the channels. I have been using the same rig for 8 years. It has cracked in a couple of places but nowhere that causes any structural issues. You have to be careful with it, but because it a very small size it is easy to handle carefully. It took quite a while to get it all figured out, but the end result was an extremely friendly and comfortable working layout. Ergonometrically speaking it would be hard to improve on. I have now removed the CDG player, the A/B switch and a few other items.
DannyG2006
Posted: Tue Dec 05, 2017 8:08 pm |
Finally got the new mixer. Below is the pictures of my setup.
| Attachments: |
karaokeniagarafalls
Posted: Wed Dec 06, 2017 3:24 am |
Joined: Wed Jul 08, 2015 5:39 am Posts: 1735 Images: 12 Location: Niagara Falls, Ontario Canada Been Liked: 190 times
I use a wiring harness consisting of 3 XLR's for the mics, 2 1/4" cables for the laptop, 1 Ethernet cable for the router, 1 balanced 1/4" for main out, 1 balanced 1/4" for monitor out, 1 power cable for the T1 Mixer. Attachment:
jdmeister
Posted: Wed Dec 06, 2017 4:24 am |
Joined: Sun Mar 24, 2002 4:12 pm Posts: 7731 Songs: 1 Location: Hollyweird, Ca. Been Liked: 1096 times
Here's a short video of an "Outdoor Gig". Look quick to see the setup. The "Table" is a 40 foot flat bed semi trailer. Yamaha paid for the gig, so it turned our OK.
Bastiat
Posted: Wed Dec 06, 2017 11:35 am |
Joined: Tue Jul 31, 2012 8:18 am Posts: 407 Been Liked: 242 times
Why someone use a router?
DannyG2006
Posted: Wed Dec 06, 2017 11:39 am |
Possible reasons include remote requests and buying on the fly or digital mixer although the picture doesn't show a digital mixer.
RLC
Posted: Wed Dec 06, 2017 12:55 pm |
DannyG2006 wrote: Possible reasons include remote requests and buying on the fly or digital mixer although the picture doesn't show a digital mixer. Danny, If your refering to karaokeniagra falls picture in your comments above, the picture certainly does show a digital mixer, the Bose T1 Tonematch which is a digital mixer. It looks like you also now have a Bose T1 Tonematch, correct?
DannyG2006
Posted: Wed Dec 06, 2017 1:23 pm |
RLC wrote: DannyG2006 wrote: Possible reasons include remote requests and buying on the fly or digital mixer although the picture doesn't show a digital mixer. Danny, If your refering to karaokeniagra falls picture in your comments above, the picture certainly does show a digital mixer, the Bose T1 Tonematch which is a digital mixer. It looks like you also now have a Bose T1 Tonematch, correct? The mixers that I consider digital usually are controlled via computer, Tablet or smartphone. As far I can see the Tonematch is more like a conventional mixer as the controls are on the mixer itself. and yes I just recently got a Tonematch. Haven't had time to use it in a real live show.
Users browsing this forum: No registered users and 2070 guests |
