KARAOKE SCENE MAGAZINE ONLINE! - Question about running a show, from a noob Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Thu Oct 29, 2026 4:07 pm
PostPosted: Mon Dec 13, 2004 4:53 pm
Hi all, my first post. I've been reading everything I can find on these forums and I appreciate all of the info I've found so far, so thanks in advance. I am not a KJ yet but I want to get into the business soon, completing my startup purchases within the next 3 months. I've got years of stage experience and have been singing karaoke for 3 years, so I know what I like when I go to a show with regard to rotation, song slips, lag between singers....all that I have a good handle on and enough experience to do well (hopefully... :shock: ).
The part I'm not sure of is what I want to ask y'all about. I am a techie by nature so I'm hoping it will all come naturally, but as of right now I have *zero* experience with amps, speakers, mixers....all that. Basically, everything that I need to know how to use. I think I'm getting an idea of what I need to buy to start out, but Im afraid that I won't learn how to use it correctly. How do I practice? Set up the whole show at home and have a dry run? I don't want to fumble for cd's and create lag between singers, don't want to have someone too loud over the music or not be able to hear the singer at all....
Bottom line, I'm nervous about sinking a lot of money into this venture if I can't handle the equipment and I'm not exactly sure how I will learn to use it. Any advice on how to just jump in and get going?
Thanks everyone,
Angela
PostPosted: Mon Dec 13, 2004 5:56 pm
I would recommend finding a show you DO like, and take notes.
This is one thing I have against people who have some experiences in some areas... they think that they can ask the right questions, and it will substitute for experience.
Wayyy wrong.
Angela, to give you credit, you're cautious about this.
We can tell you (and have over and over in many of the threads on this) what equipment works best for some of us, and why. What the comparrisons are, what the good sides and downsides are.
But what we can't give you is the experience on how to tweak a system with little bits here and there. What we can't do is show you WHY this way would be better than the others... text words only do so much.
My full recommendation is to fully read as much as you can, but then to also hook up with a current outfit, and sell yourself as a helper... even an outfit that is wayyy outside where you live. Learn from the ground up.
You don't have to be a singer to be a host... but it helps.
Best of luck to you.
PostPosted: Mon Dec 13, 2004 5:58 pm
Some people will tell you that mixing is an art. They are wrong. Mixing is 100% science and technology used to blend electrical signals to create a mix of audible signals.
Good mixing is an art. :wink: This is the ability to use that technology to create a mix that's pleasant to the ear.
My recommendations will likely be thrown out by others, but it will give you a chance to learn some basic at little to no cost while you work on the purchase of your equipment.
To learn mixing I recommend you first start recording yourself and seeing what constitues a good mix. To do this just record karaoke tracks with yourself singing and play them back to see the results. Apply effects and see how they change the music. To do this you need the computer you already have (you're posting here aren't you?), Audigy (a free software program available on the Internet), a microphone and a pair of speakers compatible with your computer. This will allow you to get an understanding of the basics of mixing. As you add equipment use that to feed the recording so you're using the same equipment you'll use at the show. Once you have all your equipment try inviting some friends over for a night of karaoke (a small group) to get a feel for finding discs, etc.
Assiting someone or even watching them (ask permission to sit close and watch if you can) can help. If they make a change on the board listen for the cooresponding change and think about if it sounds better or worse. If you can spend time with someone behind a board asking questions then jump at the chance.
That aside, I recommend the Basic series by Paul White. They are small pocket books that discuss basic techniques for effects, mixing, live sound, and other music related technical information. They are inexpensive and can give you an idea of some of the why's so you don't ask as many questions when you get a chance to work with someone behind a board.
Remember that disc management is key to being able to finding the right disc, right away. I pull a disc, que it up, and when a disc is done I carefully put it away. I never let a disc sit out where it can get knocked off the table or misplaced. All my discs are in order by manufacturer/disc number (ie. SC7501) the same way they are labeled in my books. This makes looking up a disc VERY easy for me. I'll likely be moving to a different storage mechanism for my discs soon and PC based hosting in the next 6 months or so. I found that using slim line CD cases w/ a label w/ the disc number on the front made picking discs easy but takes up some room. Books are harder to handle for a show but possible and I see plenty of shows that use them (I prefer better protection for my investment than books).
As for equipment:
Most often you'll find a variety of recommendations and here is no different. Basic recommendations will be some of the items below that have a proven track record and are able to withstand the rigors of gigging week after week. I recommend you listen to the recommendations, read the reviews, find a place to see the equipment first hand and use it if possible and then purchse. Make your own informed decisions instead of listening to what we recommend and blindly buying it.
1. CDG Player
I recommend the RSQ/JVC 333 - 3 tray player. It's inexpensive, I can que additional discs in each player and mine has been reliable. The single tray version - the 222 is also recommended quite often as reliable. Other options are the CAVS 99/199/202G that some people prefer or PC based hosting.
2. Mixer
The most often recommended is the Mackie DFX-12 for it's cost and built in effects. I use a Soundcraft Compact 10 but it's a recording mixer not well suited for live sound. Behringer is often recommended but extensive discussions regarding the reliability are often mixed (pun intended).
3. Microphones
I use Fender P-51's. They're cheap (under $50 each) and hold up well to being dropped, etc. They do require more gain than many others though. Shure SM58's are highly recommended and seem to hold up well to the rigors of karaoke shows ($100 each). The Sennheiser e835 has been discussed quite regularly and most seem to like the mic a lot ($100 each or $200 for 3).
I use a wireless mic for annoucing occasionally and there are a number of recommendations along these lines. I'll let someone else make recommendations here since I'm still doing research and haven't bought anything I'd even remotely consider recommending (hint: don't buy $30 wireless mics off eBay).
4. Amp/Speaker
Two different ways to go - powered speakers or amp+speakers. I'm going with powered speakers - either the Mackie SRM450 or the JBL Eon G2 15. Both have recieved excellent reviews on the board and from the people I know that use them regularly. These are both powered speakers.
Some people use sepereate amps/speakers and I'll have to let them discuss the specifics since I haven't done much research in this area because I'm not planning on purchasing similar equipment in the near future.
5. Cables
Use good cables and have spares. If you have problems with ground loops then feel free to ask here about resolving them - I recommend Radio Shacks Ground Loop isolator for unbalanced connections and it's inexpensive at $15 each. I keep one around to help weed out problems. You'll need more extension cords and power strips than you think you will.
6. Lighting
I have a small desk lamp and flashlight I bring with me to help find things in the dark after the show starts. It clips onto the table or my rack and is non intrusive.
7. TV
8. Stand(s)
These are all personal choices and pretty intuitive.
PostPosted: Mon Dec 13, 2004 6:16 pm
Some good information from both you guys (KnightShow and KaraokeMeister)
My thoughts on mixing:
Play a store bought CD with the type of music you intend to record yourself.
Close your eyes and listen
Record yourself
Compare store bought CD mix to your own recording
Now you start playing around.
Where to start?
The karaoke disks you buy have been studio recorded, so theoretically, with flat response studio monitors, you should keep your mixer to the 12h position on the bass, mids & treble, no EQ and you’d have perfect sound (Sound Choice CDG’s is a good start for a great karaoke mix)
Start with the treble settings. This can produce that annoying ear piercing sounds coming from the tweeters. Adjust this setting until you can hear the “ts” sound from the snare drum.
The mids are mainly for the vocal range, so sing while adjusting.
The bass, everyone knows that thump-thump sound! Be careful, too much bass is annoying and over powers all other sounds.
PostPosted: Mon Dec 13, 2004 6:59 pm
Thanks so much! What great input, I'm so glad I found these boards. To start, I certainly don't think that I can substitute any of my current experience in entertainment for technical experience with the equipment (and that's why I'm asking where to start learning how to use it... :wink: ). I've been recording and mixing my own vocals for a while on the computer with just a mic and Cool Edit with the mixer plugin, some with prerecorded background, some with acoustic guitar, so I guess I just need to learn how the actual hardware reacts. Very simply, I'm intimidated by the big slidin' buttons that I have to actually touch rather than using my mouse to make a change.
Karaokemeister, thanks for the detailed description, I truly appreciate it. I copied your post into my Palm actually, lol. Just in case I want to see it when I'm out running around. Allstar, letting me know what actual setting to start on is cool. It makes sense to me, a very clear cut way to start at a base level and tweak from there, so thank you. I never thought of comparing my own mixing to a store bought copy so I'll be doing that for sure.
Hot damn, I'm excited now lol. Thanks guys.
Angela
Users browsing this forum: No registered users and 3780 guests
