Cool Edit
https://ksmo.us/forums/viewtopic.php?f=1&t=3446
Author:  Mysticaltess [ Tue Dec 07, 2004 4:36 am ]
Post subject:  Cool Edit
I have been trying to make a recording using my cool edit software ..for some reason when I put the music in the first trac and record in the second ... when i go to playback or mix what I have done they are off by a few beats... is there a way to fix this... its like there is a delay in the recording ... the music itself is 2 or 3 beats before my voice has anyone eles had the same problem? (I have uninstalled, reinstalled and even upgraded) any thoughts on this would be appreciated. Thank you
Author:  Atomic [ Tue Dec 07, 2004 12:14 pm ]
You quite often get a slight drift depending on the latency on your soundcard.
If the track stays in time with the music, you can maximise the track (the + magnify button) and just drag it into the right place.
If the timing gets more "off" as the song goes on, I know theres a setting somewhere in CEP to compensate for that, but I can't think where it is....
I'll have a think on it, maybe it'll come to me.... :)
Author:  Mysticaltess [ Tue Dec 07, 2004 1:05 pm ]
Thank you.. I have looked all over and now I think I am just too frustrated to think clearly :cry:
Author:  Atomic [ Tue Dec 07, 2004 1:29 pm ]
OK, I found it....
When you're in multitrack mode, click on OPTIONS and then SETTINGS... then click on the MULTITRACK tab... there are 2 check boxes to the right of that window that say 1) "correct for drift in recordings" and 2) "correct for start synch in recordings"... Try checking both of those and see if that helps.....
Author:  Mysticaltess [ Tue Dec 07, 2004 1:42 pm ]
I cant thank you enough for all your help! That worked ! :D
