[ 7 posts ] |
sanj
Posted: Fri Jun 03, 2016 1:26 pm |
| Advanced Poster |
Joined: Tue Apr 28, 2009 7:24 pm Posts: 301 Been Liked: 112 times
Hi A friend of mine just purchased some GTD 787 wireless mics and a Bose with Tonematch. i was curious... Are there enough inputs on the Tonematch to run each mic? Thanks John
TopherM
Posted: Fri Jun 03, 2016 1:40 pm |
The tonematch only has 1 input, and it's not meant for a mic.
The base unit of the GTD mics has separate XR outputs for each of the four mics to be able to control them separately on a mixer.
The tonematch is more of a processing unit than a mixer. You really should still have a separate mixer, run your mics on 4 channels of that mixer for independent control of each, then run the mixer's master output through the tonematch to process the master signal.
_________________ C Mc
Robin Dean
Posted: Fri Jun 03, 2016 1:46 pm |
Joined: Wed Feb 12, 2014 5:58 am Posts: 160 Been Liked: 36 times
Tonematch has 4 inputs for mics.
RLC
Posted: Fri Jun 03, 2016 5:01 pm |
Yes, as Robin Dean stated: The Bose T1 ToneMatch has 4 inputs (3 xlr and input 4/5 Line In).
The Bose T1 ToneMatch is also a wonderful little digital mixer in its own rite!
bazinga
Posted: Fri Jun 03, 2016 5:51 pm |
Joined: Tue May 17, 2016 11:58 pm Posts: 266 Been Liked: 116 times
Another option is to use the 1/4" output from the GTD to a single input on the Tonmatch. You will loose the individual control for each mic, but you'll be able to use all four mics and connect your lappy to input 4 via USB if you need to.
sanj
Posted: Fri Jun 03, 2016 7:25 pm |
| Advanced Poster |
So, sounds like he should be OK.. Thanks for the advice... John
Posted: Sun Jun 05, 2016 5:44 am |
Joined: Sun Nov 01, 2009 4:50 pm Posts: 909 Location: Cape Breton, Nova Scotia, Canada Been Liked: 450 times
I run the 1/4" output from the GTD mixer to a single channel on my mixer... The GTD does have individual volume controls for each mic, and although I find their use is limited you can still get a fairly decent volume mix for duets etc.
_________________ Earl
[ 7 posts ] |
Users browsing this forum: No registered users and 3884 guests |
