Compuhost V3 Troubles with addons
https://ksmo.us/forums/viewtopic.php?f=1&t=34141
Author:  babs156 [ Mon Apr 18, 2016 3:31 pm ]
Post subject:  Compuhost V3 Troubles with addons
UUUUGH I have the compuhost V3 and I can't seem to get my CompuHost Songbook Creator Addon to work or even pop up in the tools/addons tab.. someone please tell me what to do because I just spent $50 so I can make a song book easily and I can't seem to get it to come up in my compuhost V3 even after I typed in the activation code and it said ti was successfully activated.
Author:  Alex [ Thu May 12, 2016 5:51 pm ]
Post subject:  Re: Compuhost V3 Troubles with addons
I had a similar problem before with the Kiosk add-on. Your best bet, and that was what I ended up doing, is to open a trouble ticket via their support website. They can walk you through. In my case I had to delete one file from the Compuhost program folder which was a leftover from an earlier version install. Good luck! :)
Author:  MtnKaraoke [ Fri May 13, 2016 11:18 am ]
I know it may seem silly, but did you actually install the add-on?
The add-on feature needs to be installed before you activate it in CH.
Author:  dsm2000 [ Fri May 13, 2016 2:41 pm ]
With 35 years in IT dealing with users, I can assure you there is no such thing as a silly question.
Author:  Bazza [ Wed May 18, 2016 9:22 am ]
And the problem is usually the nut behind the screen. :lol:
