[ 8 posts ] |
MadMusicOne
Posted: Thu Nov 26, 2015 9:51 am |
Joined: Mon Oct 24, 2011 12:41 am Posts: 652 Images: 0 Been Liked: 48 times
...Over the years, like many others here, I've added several cdgs from different Karaoke Manufacturers. One of those brands is Top Hits Monthly or also known as Panorama's THM. At one point, Stellar Records ended up with this brand. Without looking/counting, I think I have a little over 400 PTHM cd+g discs which also includes 6 KARAOKE CD+VIDEO discs (5 of them still wrapped in the cellophane). Not sure if I already have these same discs numbers on CD+G discs or not, would have to look.
...On a side note, when playing these discs, from a player or laptop, they are similar to the Laser Discs (lyrics overlay with "music video" in the background).
...So, my question, is there anyway to rip/convert the (.dat) files from these KARAOKE CD+VIDEO discs to MP3+G or not? Even if I still have them in CD+G discs, am still curious if they can be ripped/converted to mp3+g files. Thanks!
karaokeniagarafalls
Posted: Thu Nov 26, 2015 11:16 am |
Joined: Wed Jul 08, 2015 5:39 am Posts: 1735 Images: 12 Location: Niagara Falls, Ontario Canada Been Liked: 190 times
MadMusicOne wrote: ...Over the years, like many others here, I've added several cdgs from different Karaoke Manufacturers. One of those brands is Top Hits Monthly or also known as Panorama's THM. At one point, Stellar Records ended up with this brand. Without looking/counting, I think I have a little over 400 PTHM cd+g discs which also includes 6 KARAOKE CD+VIDEO discs (5 of them still wrapped in the cellophane). Not sure if I already have these same discs numbers on CD+G discs or not, would have to look.
...So, my question, is there anyway to rip/convert the (.dat) files from these KARAOKE CD+VIDEO discs to MP3+G or not? Even if I still have them in CD+G discs, am still curious if they can be ripped/converted to mp3+g files. Thanks! Do those disks mention CAVS on them? if so you can convert the .dat to mp3+g using Power SCDG Ripper
MadMusicOne
Posted: Thu Nov 26, 2015 2:25 pm |
karaokeniagarafalls wrote: MadMusicOne wrote: ...Over the years, like many others here, I've added several cdgs from different Karaoke Manufacturers. One of those brands is Top Hits Monthly or also known as Panorama's THM. At one point, Stellar Records ended up with this brand. Without looking/counting, I think I have a little over 400 PTHM cd+g discs which also includes 6 KARAOKE CD+VIDEO discs (5 of them still wrapped in the cellophane). Not sure if I already have these same discs numbers on CD+G discs or not, would have to look.
...So, my question, is there anyway to rip/convert the (.dat) files from these KARAOKE CD+VIDEO discs to MP3+G or not? Even if I still have them in CD+G discs, am still curious if they can be ripped/converted to mp3+g files. Thanks! Do those disks mention CAVS on them? if so you can convert the .dat to mp3+g using Power SCDG Ripper ...Nope, no mention of CAVS but thanks!
MadMusicOne
Posted: Thu Nov 26, 2015 2:29 pm |
bazinga wrote: Your discs sounds more like the VCDs. Try taking one of the dat file and saving it to your desktop and change the extension to .mpg. If it's anything like a VCD, you can convert it to a mpg file and use it with any hosting program that plays mpg files. ...Tried that a few days ago and just now with same results: Static instead of music and on the screen, nothing but a colored square box inside of another different square box where the lyrics should be. ...but thanks for the tip!
Paradigm Karaoke
Posted: Thu Nov 26, 2015 11:37 pm |
Joined: Thu Aug 12, 2010 6:24 pm Posts: 5108 Location: Phoenix Az Been Liked: 1280 times
you MAY need to treat them like the laserdiscs. i think Lonnie and Mrmarog did that.
mrmarog
Posted: Fri Nov 27, 2015 6:17 am |
Paradigm Karaoke wrote: you MAY need to treat them like the laserdiscs. i think Lonnie and Mrmarog did that. Yes, you need to capture the video by playing and recording in "real time".
summergleason
Posted: Fri Nov 27, 2015 6:55 am |
Joined: Tue Jun 07, 2011 9:04 am Posts: 90 Been Liked: 12 times
Renaming .dat to mpg should work. You might need to install the proper codecs. Go to the Siglos Karaoke forum and you will see others asking what you want. Search in the forum .dat to mpeg
mrmarog
Posted: Fri Nov 27, 2015 7:23 am |
summergleason wrote: Renaming .dat to mpg should work. You might need to install the proper codecs. Go to the Siglos Karaoke forum and you will see others asking what you want. Search in the forum .dat to mpeg If that works then that would be the way to go.
[ 8 posts ] |
Users browsing this forum: No registered users and 3903 guests |
