KARAOKE SCENE MAGAZINE ONLINE! - Compuhost advanced media player problem Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Thu Oct 29, 2026 12:04 pm
PostPosted: Sat Oct 10, 2015 7:42 am
Using the Compuhost Advanced Media player for discs, when we chose the track and hit the start/stop button, the disc did not open in Compuhost as it usually does. It opened the file in Windows media player and just played music with no video. I rebooted the program but it still happened. Has anyone had this occur? Any suggestions how to fix?
PostPosted: Sun Oct 11, 2015 7:19 am
Right click on the file, select properties, change from media player to compuhost..
PostPosted: Sun Oct 11, 2015 8:51 am
Been Liked: 259 times
You need to reset the default program for opening .cda and .cdg file types to Compuhost.
Left click Start-Control Panel-Default Programs-Associate a file type or protocol with a specific program.
left double click the .cda extension. Choose Compuhost to always open .cda files(If Compuhost is not in the list you need to click choose more programs and then find the Compuhost.exe file on your harddrive and choose it.
Same process for .cdg files.
google the phrase "Associate a file type" and you will find step by step with pictures for whatever operating system you are using.
PostPosted: Fri Oct 16, 2015 1:26 pm
I have a second backup computer that also has compuhost and compared the default programs. Neither one even lists cdg as a file type. The backup computer plays discs fine. So I am thinking that that is not the issue.
PostPosted: Fri Oct 16, 2015 1:58 pm
Been Liked: 31 times
What version are you using? I've found v2.50.04 the most stable for me. Does CDGrip work?
PostPosted: Fri Oct 16, 2015 2:26 pm
I updated today to 2.51.6.0. Still experiencing the same problem.
PostPosted: Fri Oct 16, 2015 2:30 pm
Also, I do not use CDGrip.
PostPosted: Fri Oct 16, 2015 6:05 pm
Whether you choose to follow the advice or not is your choice but the answer to your problem was given first by jdmeister and then by dsm2000, two different ways to do the same...associate the file type with the correct program to open it.
PostPosted: Sat Oct 17, 2015 6:40 am
.cdg is not A file type option. So that "solution" will not work for me.
PostPosted: Sat Oct 17, 2015 7:10 am
Navigate to your d: e: whatever your cd drive is that contains your cdg cd.
in file explorer you will probably only see files named track 1 track 2 track 3 etc.
RIGHT double click one of the track files.
choose Open With
If Compuhost is not in the list, choose more programs
navigate to the folder where the compuhost program file is stored.
choose the comuhost application file (.exe)
check the box that says "Always use this program to open this type of file
Left double clicking the track files(.cda) should now open in Compuhost as before.
PostPosted: Sun Oct 18, 2015 5:51 am
Thank you to everyone for your ideas and suggestions. Although changing the file default did not work, I know more about file types and defaults. =)
I put in a support ticket to Compuhost. They sent me a link to re-install the full software. Hopefully that will do the trick.
Thanks much, my karaoke people for all your comments and suggestions! =)
Users browsing this forum: No registered users and 3782 guests
