KARAOKE SCENE MAGAZINE ONLINE! - Music (mp3) in Karma Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Thu Oct 29, 2026 1:35 am
 Post subject: Music (mp3) in Karma
PostPosted: Sun Sep 06, 2015 6:32 am
I have a folder called Country where I have all my subfolders by artists
another folder called Bluegrass with subfolders by artist
then I have a folder called oldies with subfolders called 50's another called 60's and one more called 70's
how can I search for a certain Folder for instance I just want to see all the songs in my 60's folder
not everything else .....
thanks
Mike
 Post subject: Re: Music (mp3) in Karma
PostPosted: Sun Sep 06, 2015 8:05 pm
Been Liked: 224 times
Create a category for each specific folder, direct the category to that particular folder and then update the database. So the Country category would go to the Country folder and then when you choose that category, you will only see content of that folder and sub-folders (make sure you check that off in the setup). All that content will still be available when you search all your music.
PostPosted: Mon Sep 07, 2015 5:55 am
Or you can use KJFile Manager and use the "parent file name" feature and rename the disc ID field however you wish. For instance:
SCO60 Sound Choice Oldies 60's
MMC90 Music Maestro Country 90's
Use your imagination, but before renaming use "write a tag" feature so you can revert back if you want.
PostPosted: Mon Sep 07, 2015 7:51 am
Thank you so much
After several years
Yawl helped me
AND IT'S WORKING
Thank you so much
Users browsing this forum: No registered users and 2153 guests
