| Looking for a small monitor ...5IN - 9IN https://ksmo.us/forums/viewtopic.php?f=1&t=3040 |
| Author: | jamkaraoke [ Fri Oct 29, 2004 10:01 am ] |
| Post subject: | Looking for a small monitor ...5IN - 9IN |
As some KJ's do I DJ from time to time , parties . weddings, birthdays ..you name it. Being that like many I love to sing I usually sing some songs when I DJ ..crowd usually likes its Long Story short I'm looking for a little individual video monitor that won't be to noticiable on my DJ table. Vocopro Anyone using or have seen such a unit TV or Monitor ..with A/V plugs of course ? |
| Author: | Lonman [ Fri Oct 29, 2004 11:42 am ] |
| Post subject: | |
Rat Shack used to have little 5" monitors. Magnavox used to have a 5", I have 2 in my system as cue monitors, but I think they were discontinued. |
| Author: | knightshow [ Fri Oct 29, 2004 6:28 pm ] |
| Post subject: | |
you can find little "travel" black and white tvs that have a radio built in. I got a couple from walgreens, for $25... then found them even cheaper somewhere else! Look for automobile accessories. They usually come with dual power accessories... one for the 12V cigarette lighter, and another for 120volt normal "house" current. The ones I have came with a mono audio hook up and of course, the yellow video. |
| Author: | big jimmy c [ Sat Oct 30, 2004 12:16 pm ] |
| Post subject: | |
Yeah, I bought one of those cheapo b/w tv's once. It lasted a very short time. |
| Author: | knightshow [ Sat Oct 30, 2004 2:31 pm ] |
| Post subject: | |
both of mine have been going strong for a while now... almost a year! |
| Author: | big jimmy c [ Sat Oct 30, 2004 10:43 pm ] |
| Post subject: | |
Matt, Maybe your power source is more consistant than mine. In my apt I get digital voltage readings between 125 - 130 depending on the time of day or night. At my gig its 113 - 115. Regardless of the variety of volts, Those mini B/W's are made for the landfill. |
| Author: | karaokemeister [ Sun Oct 31, 2004 12:06 am ] |
| Post subject: | |
Try searching google for 5" lcd tv. Prices are in the $150 range for most vendors. |
| Author: | knightshow [ Sun Oct 31, 2004 6:23 am ] |
| Post subject: | |
big jimmy c wrote: Matt, Maybe your power source is more consistant than mine. Dunno dude... I hook them up to the same outlet that my main system hooks up to! I've never yet had to check the actual voltage to see how it really comes out. I have a third TV I have at home that I do the same thing on my computer (farm out the video to the portable tv sitting next to it)... it's hooked up thru a power strip... never had any issues!
In my apt I get digital voltage readings between 125 - 130 depending on the time of day or night. At my gig its 113 - 115. Regardless of the variety of volts, Those mini B/W's are made for the landfill. Sorry about your woes... that SUCKS! |
| Author: | anhnguyen310 [ Mon Nov 01, 2004 12:58 pm ] |
| Post subject: | |
you should look into some LCD screens. The raw ones sell for fairly cheap if u know how to wire them up. The prebuilt ones will run u around 150 to 1k depending on what size you want. A 5" would probally cost you around 150 to 200. I would suggest you get a 7" because you can actually read on it. I installed a 7" screen in my gfs car and u can easily read subtitles. Hope this helps. -Anh |
| Author: | knightshow [ Mon Nov 01, 2004 3:26 pm ] |
| Post subject: | |
I think the $25.00 option is far better ! !
| Author: | kojak [ Tue Nov 02, 2004 2:20 am ] |
| Post subject: | |
I have a small black & white "travel" TV that works just fine with one exception... It's rather difficult to see the color change, (go figure). On some disks the color change is of a lower contrast than others, i.e. on some disks the color change is hard to see, and on others it's next to impossible. If you don't need the color change, it's a moot point, but if you do it's something to consider. Good Luck! Kojak |
| Author: | snowman [ Wed Nov 03, 2004 2:39 am ] |
| Post subject: | |
I use a 7" portable dvd player very small and with the flip up screen very convienent. You can get them for pretty cheap on the back it has video in and video out switch. It is an 1/8" female audio plug |
| Author: | jamkaraoke [ Wed Nov 03, 2004 9:46 am ] |
| Post subject: | |
Thanks! ..I've been doing my share of surfing and searching and for my purpose I might go with a little B&W TV , I don't need the color change as most know ..If you follow that when singing ...You'll get lost Thanks Again |
