KARAOKE SCENE MAGAZINE ONLINE! - Lyric wiping tips for super fast songs Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Thu Oct 29, 2026 2:33 am
PostPosted: Sun May 25, 2014 5:51 pm
Can anyone provide lyric wiping tips for super fast Karaoke songs? I am trying to create "Ill Mind Of Hopsin 5" using Karaoke Builder Studio with little luck. I can time the track out perfectly when it plays on the in-program screen, but he CDG can't keep up with the wiping when produced. Have had this problem with other fast songs too. Any suggestions would be appreciated. Thanks!
PostPosted: Mon May 26, 2014 11:45 am
Most likely it's the font type/size possibly how many lines per page, line by line wipes as opposed to clear screen paging you are using. Some fonts take longer to render on the screen.
PostPosted: Sat Jun 21, 2014 12:03 pm
Been Liked: 8 times
This post was posted twice, so the answer is below. After listening to that song, I would highly suggest you use no outline and set the highlight quality to "FAST WIPING". Word for word is not a great idea as it makes the words jerk into place.
Please, Read the next post I made and it will tell you what you need to do in order to make your rap song appear properly.
PostPosted: Sat Jun 21, 2014 12:07 pm
Been Liked: 8 times
Hi, the problem is most likely you are using outline around your song? In the right hand corner you will see (Wipe type: Set to txt) Below that you will see boxes marked outline (left, right, top, bottom). Set these values from 2 to all 0's.
Some people make the mistake of making a track and coloring the outline setting to the screen color. This does not eliminate the outline drawing from being done, you need to tell it physically to not draw the additional pixels and binary codes.
I am new here, so I will need to see if I can upload a picture. You can use their demo song "Devil Went Down To Georgia" and look at the settings. They removed the actual outline draw which is located above the shadow areas. When making fast tunes, these should be set to all 0's.
Binary in their program only draws so fast. I have a program that is way more complex over KBStudio or even MTU's Workstation. I have not done any author work in a long time, but can do rap and keep the outline. This works on a VERY old platform though that was out way before MTU's Workstation. Try what I have suggested and let me know :D
Users browsing this forum: No registered users and 1706 guests
