chrisavis
Posted: Thu Jan 23, 2014 1:20 pm |
I am considering eliminating multiple versions of songs that I don't believe will ever get requested. I estimate I can reduce the number of tracks I have by 60% or more by doing this. What I am looking for are suggestions on how to do this easily and quickly. All of my files are in the following format:
DiscID-Track# - Artist - Title.zip Example - SC10001-01 - Haley, Bill & The Comets - Rock Around The Clock.zip
or for downloads which don't have a track #
TrackID - Artist - Title.zip Example - KV287814 - ZZ Ward - Put The Gun Down.zip
Videos use the same format with the appropriate extension.
Any suggestions?
_________________ -Chris
chrisavis
Posted: Thu Jan 23, 2014 1:40 pm |
I may have an answer for this (doh!)
I have always been afraid to use the Duplicate Song Finder Option in the Karoasoft KJ File Manager tool. Just didn't want to wipe out files by accident. I just ran it using the Duplicate Search and it appears to have found all files that are duplicated by Artist + Title. Pretty much exactly what I am looking for.
Now it appears I have the manual task of identifying which version of a track to keep and just Moving them unwanted files to another folder. Yet another LONG TEDIOUS task, but one that will pay off big time in the long run.
Is this what other folks have done to clean things up? Any other better system to use?
Lord Burnstrum
Posted: Thu Jan 23, 2014 6:36 pm |
Joined: Tue May 03, 2011 2:17 pm Posts: 413 Location: United Kingdom Been Liked: 38 times
I would suggest, if it's possible, to do it in such a way that you can easily call them up at the drop of a hat should a particular version get requested. Depends what the reason for removing the duplicates is I guess. If it's to try and make your computer run smoother, maybe you could put the dupes on a USB hard drive/memory stick of their own, so if you do get a "You got X version of that song? I'm set on that brand" type of singer (such as yours truly!) it's just a case of plug and play.
rickgood
Posted: Thu Jan 23, 2014 8:06 pm |
Joined: Tue May 31, 2011 7:09 pm Posts: 839 Location: Myrtle Beach, SC Been Liked: 224 times
Chris,
I think the question is why you want to get rid of dupes? I tried that once and set up two karaoke folders in karma - one main karaoke and one extra karaoke. That way I could quickly search either of the folders. If you have a lot of SC, which I think you do, there are a ton of duplicates throughout their library.
Is it to make your book smaller? With hard drive space being so cheap I'm not sure what your motivation is to delete them. I always like having my whole library available at a show.
chrisavis
Posted: Thu Jan 23, 2014 9:53 pm |
I am operating at scale which means -
-overall backup/restore times can be dramatically reduced by eliminating duplicates -training new hosts on what version to select is eliminated (I don't get too many 'must sing the Druid Performance Tracks version of "Cathy's Clown" by Reba McEntire' types) -identify duplication to allow me to expand without further duplication (reduce music purchasing) -sell off discs I simply will never use to recoup expenses (I need exactly ZERO BackStage discs and have something like 8 complete sets now)
....and.....
I have my own OCD ticks and this one has started to twitch.
RLC
Posted: Fri Jan 24, 2014 5:30 am |
chrisavis wrote: ....and.....
-Chris  Don't we all?
frede
Posted: Fri Jan 24, 2014 7:19 am |
Joined: Sun Nov 13, 2011 7:37 am Posts: 304 Location: Washington D.C. Been Liked: 31 times
chrisavis wrote: I may have an answer for this (doh!)
<snip>
-Chris Here's what I'd do: Create a "Duplicate" folder with a subfolder called "BackStage", sort on Disc ID and MOVE the duplicate BackStage songs into it. Rinse and Repeat. Warning: "Delete" in KJFM is absolute!
_________________ Karaoke that just sounds better!
mrmarog
Posted: Fri Jan 24, 2014 8:25 am |
I have removed dupes very simply by dropping all songs into 1 folder, then I remove disc data except for manu codes (SC,MM, CB, etc) using KJFM (split at 3rd character from left in disc ID and discard the right). Then when KJFM renames them with short ID names and an identical songs already exists, it will ask you to move the dupe files to another location. Done in minutes! What you will end up with is only one of every manu that you have, and your spares will still have the full ID.
Posted: Fri Jan 24, 2014 4:37 pm |
I agree with not deleting from the hard drive. Books, yes. True 9 out of 10 times you are going to go to your go to pick that you feel is the best version, but it's nice when you can offer another version to someone who is used to something else and doesn't like the go to pick.
chrisavis
Posted: Fri Jan 24, 2014 10:57 pm |
Lonman wrote: I agree with not deleting from the hard drive. Books, yes. True 9 out of 10 times you are going to go to your go to pick that you feel is the best version, but it's nice when you can offer another version to someone who is used to something else and doesn't like the go to pick. I would feel the same way if I only ran a single rig. But it just isn't cost effective to have every rig be identical. And the backup/restore process across so many rigs is very time consuming. Not to mention, where we host, we have that younger crowd that is far less sensitive to brands than the older generation of singers. -Chris
JoeChartreuse
Posted: Sat Jan 25, 2014 12:13 am |
Chris, pardon me if I'm asking a dumb question, but after reading the thread I still have no idea what songbook software you are using- that is, if it's the BOOKS from which you wish to delete. I'm assuming ( being PC based) you want to keep dupe versions from multiple mfrs. on your HD.
Pjskaraokeuk
Posted: Sat Jan 25, 2014 1:49 am |
| Major Poster |
Joined: Sat Dec 28, 2013 1:19 am Posts: 50 Location: From UK but living in Cyprus Been Liked: 1 time
I Export list to excel and remove dups from my book only
_________________ facebook - PJs Karaoke Disco
chrisavis
Posted: Sat Jan 25, 2014 3:20 am |
I am removing the duplicates from my hard drive. I removed probably 98% of the dupes from my books a year ago. Now I want to clean up hard drives for the reason above.
BruceFan4Life
Posted: Sat Jan 25, 2014 12:26 pm |
| Super Duper Poster |
Joined: Wed May 18, 2005 10:03 pm Posts: 2674 Location: Jersey Been Liked: 160 times
If I wanted to pare down my library for a particular hard drive, I would just put the major brands on it like SC, DK, PHM, Legends and Pocket Songs. That would be my core. There would still be some duplicates but you would have most people covered. To that I would add the KV tracks that I have purchased because I probably don't have any other versions of those songs. There would be certain songs that my regulars sang on a steady basis so I would also add those songs. Then I would keep track of any song that a customer requested that wasn't on my internal laptop hard drive and add those songs as they were requested. If someone asked to sing a song from a Monster Hits disc, I would add that entire disc to my main drive unless I was running out of space. After a short period of time, you probably wouldn't be accessing your external drive for many songs at all and you probably wouldn't even have to hook it up on most nights. Seems to me that it would take a lot less time than checking through many thousands of individual files and deleting them one at a time.
exweedfarmer
Posted: Sat Jan 25, 2014 1:54 pm |
Are all the songs in the same folder?
simon67
Posted: Sat Feb 15, 2014 4:11 am |
Joined: Sat Feb 15, 2014 3:46 am Posts: 1 Been Liked: 0 time
I used DuplicateFilesDeleter and I was extremely pleased with the result.
Lshiny
Posted: Mon Feb 17, 2014 12:33 am |
Joined: Tue Feb 20, 2007 9:38 am Posts: 77 Location: Fort Wayne, IN Been Liked: 3 times
Song List Generator from Karaosoft could help. Import all of the karaoke tracks, toggle the show all versions button, The Versions column will list all the different brands you have. You can export a list as a csv or xls file. Ironically, it does not show you if you have more than one of the same brand.
_________________ Swing Time Karaoke
mrmarog
Posted: Mon Feb 17, 2014 4:29 am |
I've said it earlier, but here it is again. 1) Put all your songs in one folder and tag them with proper disc, artist and song info. 2) Use KJFileManager (Karaosoft) and strip all data from the disc id except for the Manu code (SC CB MM, etc) 3) When done all the dupes will return a message "cannot perform request when the file already exists, what would you like to do with those unprocessed files" (this is the jest of the quote) 4) Move those files that still have ALL the disc ID info intact to a "dupe 1" folder 5) Go back to the files that have the stripped disc ID and read the tag and perform "tag to file" operation 6) You now have only 1 of every manufacturer in the list and if you are trying to maximize your songs for multiple rigs this would work very well (Chris).
It is very simple and only requires waiting for the results and no tedious hand sorting. You can perform the same task with your "dupe 1" folder and remove the remaining dupes to "dupe 2" folder ...... rinse and repeat.
I have around 4500 unique cd's and a massive amount of dupes within 1 manufacturer, so this dramatically reduced the searched field.
alexias
Posted: Fri Nov 21, 2014 1:53 am |
Joined: Fri Nov 21, 2014 1:51 am Posts: 1 Been Liked: 0 time
DuplicateFilesDeleter works excellent to find duplicate files and delete them quickly than other software. You may also try it and I m sure you will be happy too. Thank you!
Alfke
Posted: Tue Nov 25, 2014 1:45 pm |
Joined: Thu Sep 04, 2014 8:06 pm Posts: 38 Been Liked: 10 times
For me, I use KJFile manager to edit the songs to the format DISCID - Artist - Title. I pull a list of my current collection with SongListGenerator and filter out the duplicates. Anything I add to my collection is checked to ensure the title and artist is matched precisely for all manufacturers. The benefit to doing this is SongListGenerator will spit out a song list with no duplicates, but can easily show the different manufacturer versions
Users browsing this forum: No registered users and 1865 guests |
