[ 16 posts ] |
Rev1274
Posted: Fri Oct 04, 2013 6:29 pm |
Joined: Fri Sep 06, 2013 4:44 am Posts: 137 Been Liked: 1 time
Hi, I have a Pioneer v880 that looks like  Is there something that makes the reader of the Laser disc better so that it can read? It doesn't read that well, any ways to improve it?
mightywiz
Posted: Fri Oct 04, 2013 7:04 pm |
Joined: Thu Jul 07, 2011 12:35 pm Posts: 1351 Images: 1 Location: Idaho Been Liked: 180 times
probably just time to replace the laser pickup...
_________________ It's all good!
Rev1274
Posted: Fri Oct 04, 2013 7:12 pm |
Sorry im not tech smart or Karaoke smart but what do you mean replacing?
JoeChartreuse
Posted: Fri Oct 04, 2013 10:48 pm |
Rev1274 wrote: Hi, I have a Pioneer v880 that looks like  Is there something that makes the reader of the Laser disc better so that it can read? It doesn't read that well, any ways to improve it? While it MAY be time to replace the laser pickup, one might consider the laser discs themselves, which are well aged. It could be that the discs themselves are the problem. Have you tested them on other machines?
Rev1274
Posted: Sat Oct 05, 2013 12:30 am |
I don't use the v880 just for Laser discs. I use my CDG and Laser discs on it. I have problems playing CDG's with bad quality. Like the older Pop Hits Monthly, I have problems with it. Or burnt CDG's I have problems with it also.
Some laser machines work better than others, and Im guessing its the laser reading?
Or is there anyway to clean the lens reader?
chrisavis
Posted: Sat Oct 05, 2013 1:30 am |
Time to replace with...... a PC.  -Chris
_________________ -Chris
Brian A
Posted: Sat Oct 05, 2013 1:57 am |
Dust makes the lens dirty. Tried this laser cleaner? http://www.amazon.com/Allsop-56500-CD-L ... B00000J1QKSmoke-filled room & static charge also leaves a little film on it & can affect performance - that would require 'wet' cleaning. I normally use q-tip with slight amount of windex, rub the lens gently, repeat & dry. Do not touch the lens housing. If the problem still exists, most likely you will need to replace the laser pick-up. Years back when I had my Pioneer cld 303t I found out that you cannot repair that optical pickup. This was according to the geek tech. He said it requires replacement, then recalibration, aligned & sync with the player or it will not work properly. Expensive! Not worth fixing imo. What would be the cheaper & economical recourse? I just bought another used functional ld player @ ebay. Good luck!
_________________ To be fortunate enough to derive an income from a source as fulfilling as karaoke music has got to be as close to heaven as we can get here on earth!
Cueball
Posted: Sat Oct 05, 2013 8:25 am |
Joined: Sat Oct 20, 2001 6:55 pm Posts: 4436 Location: New York City Been Liked: 758 times
Have you always had this problem, or is this a recent development? You might need the Optical Lens Assembly replaced if you're having trouble reading all of the discs you load. Other than that, Brian's suggestion of a Lens Cleaning is a good idea to try first.
mightywiz
Posted: Sat Oct 05, 2013 9:28 am |
cueball wrote: Have you always had this problem, or is this a recent development? You might need the Optical Lens Assembly replaced if you're having trouble reading all of the discs you load. Other than that, Brian's suggestion of a Lens Cleaning is a good idea to try first. laser assembly, optical lens assembly..... all the same thing... here is a link with a picture: http://www.logictoyz.com/ld-laser-diode-laser-lens-and-laser-module/pioneer-vwt1110-carriage-assembly-ld-optical-pick-up-vwt-1110-cld-laser-lens-.htmlhere is pioneer's link for ordering the part in the usa: http://parts.pioneerelectronics.com/part.asp?productNum=VWT1110and yes cleaning the lens is the first thing you should try, but forget the cleaning disc's. they suck!!!!!! take a q-tip and a little isoprophyl alcohol and clean the laser manually, here is a youtube video to show you how, concept is the same for cleaning the laser so just open you v880 and clean the laser lens the same way:
leopard lizard
Posted: Sat Oct 05, 2013 9:38 am |
Joined: Thu Sep 04, 2008 4:18 pm Posts: 2593 Been Liked: 295 times
If you don't feel up to tackling the job yourself, Bayview Electronics in Olympia, WA specializes in old Pioneer repair. You can email them what is happening and they are very nice about giving you a guess as to what the problem probably is and how much it would be to fix it. http://www.laserdiscservice.com/
Posted: Mon Oct 07, 2013 1:18 pm |
leopard lizard wrote: If you don't feel up to tackling the job yourself, Bayview Electronics in Olympia, WA specializes in old Pioneer repair. You can email them what is happening and they are very nice about giving you a guess as to what the problem probably is and how much it would be to fix it. http://www.laserdiscservice.com/This is about the ONLY place that does laserdisc service - but they do a really good job at it. They've been servicing and cleaning my machines for years. Nice that I can just drive up there though instead of shipping it. To the OP! If your machine has NEVER been cleaned & isn't reading cdg's or burns very good, get it cleaned! I have that same machine and it's never even hiccup'd a graphic on cdg's or burned discs - UNLESS the laser was dirty.
SwingcatKurt
Posted: Mon Oct 07, 2013 4:03 pm |
Joined: Thu Dec 25, 2003 10:35 pm Posts: 1889 Images: 1 Location: portland, oregon Been Liked: 59 times
Make sure you CLEAN each disk COMPLETELY of any smudges fingerprints or other gunk accumulated on the disc surface before inserting into the machine. MAKES A WORLD OF DIFFERENCE. May just be dirty discs.
_________________ "You know that I sing the Blues and I do not suffer fools. When I'm on that silver mic, it's gonna cut ya, just like a knife"-The SWINGCAT
Rev1274
Posted: Fri Oct 11, 2013 4:33 pm |
I've been using these discs since early 90s and some of them don't have scratches on it. But I have a problem with few players where some play and some don't play.
Rev1274
Posted: Fri Oct 11, 2013 4:34 pm |
Brian A wrote: Dust makes the lens dirty. Tried this laser cleaner? http://www.amazon.com/Allsop-56500-CD-L ... B00000J1QKSmoke-filled room & static charge also leaves a little film on it & can affect performance - that would require 'wet' cleaning. I normally use q-tip with slight amount of windex, rub the lens gently, repeat & dry. Do not touch the lens housing. If the problem still exists, most likely you will need to replace the laser pick-up. Years back when I had my Pioneer cld 303t I found out that you cannot repair that optical pickup. This was according to the geek tech. He said it requires replacement, then recalibration, aligned & sync with the player or it will not work properly. Expensive! Not worth fixing imo. What would be the cheaper & economical recourse? I just bought another used functional ld player @ ebay. Good luck! I tried certain laser cleaners, but never noticed the difference. Is the link the laser cleaner better?
mightywiz
Posted: Fri Oct 11, 2013 5:20 pm |
cleaning disc's don't work very good......
the disc spins in one direction pushing debris to one side of the laser, and some lenses are beveled and have a raised edge circling the edge of the lens.
so they are kind of pointless, do the q-tip and alcohol as I suggested, it's pretty easy and won't cost you $50 bucks.....
Rev1274
Posted: Fri Oct 11, 2013 6:58 pm |
Thanks I'll look into it. Money like $50.00 and $100.00 is not really a big problem for me, as this is a business where I have to make sure that I get the best results to fix it, so that I don't get interfered during business time. I'll look at the Qtip and also the laserdisc url for the WA.
[ 16 posts ] |
Users browsing this forum: No registered users and 3602 guests |
