| I'M BLEEDING https://ksmo.us/forums/viewtopic.php?f=1&t=2722 |
| Author: | ok What Now [ Sat Sep 25, 2004 7:29 am ] |
| Post subject: | I'M BLEEDING |
yep that got you here... ...ok heres my pro....my music track is bleeding thru into my vocal track, and i can't figure out whats wrong r different from my normal setup...i unplugged the mic and its still there....
i'm useing an Extigy soundcard... an external mixer and a external reverb i checked all my setting on my comp. and i believe there all set the same as before when there was no bleed thru.... Could it be some cable r a bad imput? i'm lost here, but my mixes suck... ...and i have to work my butt off to get them to even sound that good, because when it picks up the music its also picking up and adding reverb, r any other f/x...
there is a $1.000 reward to anyone who helps me first....rrrrrr a 20 yr paid membership to s/s.....did i say i was kkkkkk?
thanks so much |
| Author: | karaokemeister [ Sat Sep 25, 2004 12:03 pm ] |
| Post subject: | |
A little more information please... Which mixer/effects are you using? How are they hooked up? Once you do that, double check the mixer settings. If you're not recording them together then only the mic will go through the mixer (or both with only the mic set to record). My guess is that the computer is plugged into the mixer on a channel and you're mixing the vocals w/ the audio. The audio track is also set to go through the effects causing the problem w/ the effects being applied to the music. I don't know how you normally record - vocals only, vocals w/ music, or if you're multitracking directly from the mixer. I'm guessing that you are only running the vocals through the mixer and the problem is as stated above. If this doesn't fix it let us know how the equipment is connected together and what/how you're recording. And I'll pass on the rewards...well.... uh.... nah... I'll pass - this time... |
| Author: | ok What Now [ Sat Sep 25, 2004 12:18 pm ] |
| Post subject: | |
hi KM....i'm useing a behringer 802a 6 channel mixer, and a midiverb 3 reverb.... yes i record my vocals only thru the mixer the f/x i don't record the f/x r in stereo aux return and send 1... on aux send 2 i come out to my line in on my soundcard from line in on my mixer left / right, i go to the plug marked FRONT ON THE BACK OF MY SOUNDCARD....thats my music i believe.... thats about it.....ty so much for responding, if u r the lucky winner, you just know the checks in the mail... ...tyyyyyyyyy
| Author: | ok What Now [ Sat Sep 25, 2004 12:24 pm ] |
| Post subject: | |
ok i figured it out....as soon as i said i think thats my music , i went looking and my post fade was up...grrrrrrr.... ty so muchhhhhhh for ur help .....TYYYYYYYYY |
