KARAOKE SCENE MAGAZINE ONLINE! - Mixer Questions Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Wed Oct 28, 2026 3:14 am
 Post subject: Mixer Questions
PostPosted: Sat Sep 18, 2004 10:10 am
Ok I have a few questions
1.: I have a Behringer eurorack mx1604a, and I would like to use this for my 2nd set up I know it does not have efx. What other hardware can I buy to add efx?
2.: Would it just be better to buy another mixer?
3.: is there some where I can go to find out what all the knobs and inserts etc... do?
if you have any links please click on my WWW at the bottom and go to my mesage board and let me know (I know you can't post links here) Post all links where it says links. Thanks alot.
If you have a link for me click on my WWW at the bottom and post it there.
PostPosted: Sat Sep 18, 2004 11:16 am
You don't need to get rid of your mixer, you would just need an external effect processor. I won't make recommendations here & definately won't put a link or even an address here to help you find the answer to your problem.
I answered on your message board to give you the real info including links, anyone else interested can get the links there.
PostPosted: Sat Sep 18, 2004 11:29 am
Thanks that is what I was looking for.
PostPosted: Mon Sep 20, 2004 2:29 pm
Ok more question I am looking for a mixer with effect built on. I don't have tons of money to spend on it. can someone point me ikn the right direction?
PostPosted: Mon Sep 20, 2004 2:36 pm
I really liked the Mackie DFX12... doesn't have the midrange, though.
The CFX12 that Lonman uses has it though... it's the next "better" model.
DO some searches... the DFX12 runs about $239 from a yahoo search!
PostPosted: Mon Sep 20, 2004 2:38 pm
Agree the DFX12 is a good board. It uses the same effects as the CFX12.
PostPosted: Mon Sep 20, 2004 2:54 pm
I have a 31 band dbx eq, will that help with the midrange? I really like that mixer.
PostPosted: Mon Sep 20, 2004 3:19 pm
The 31 band eq can be used, if you already have it, then definately put it in line. I would use it more for feedback control & a slight tonal shaping. Even though the DFX doesn't technically have midrange controls on the channels, you can fake it by lowering the lo's & highs a little, otherwise it also has a 5 band eq you could tap the midrange up if needed overall.
PostPosted: Mon Sep 20, 2004 3:23 pm
Ok I am off to buy a DFX12
PostPosted: Mon Sep 20, 2004 7:37 pm
Check Ebay for listings on a CFX12 also. Recently, I picked up the CFX12 on Ebay for $335.00. It was barely, if at all, used. It did not come with the manual or the original packaging, but it was in pristine like new condition. The ad said it was tested once to verify that it worked and that seemed to be accurate. Besides, you can always download the manual from Mackie's website. However, you cannot go wrong with the DFX12.
Cheers
PostPosted: Tue Sep 21, 2004 10:19 am
problem with that is, the warrenty is void if you buy from other than a retailer!
Users browsing this forum: No registered users and 2896 guests
