KARAOKE SCENE MAGAZINE ONLINE! - Question about RF and Electrical Interference Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Mon Oct 26, 2026 10:35 pm
PostPosted: Fri Aug 27, 2004 7:29 am
I know almost nothing about how electricity affects our microphones,but I noticed something today in my search for a remedy to a mic problem I am having.
There is a 220 outlet only 1 inch from my computer,my mic cord is also very close to it.Sometimes my mic cord may lay directly on top of it.
I know nothing about electrivity,and I am wondering if this may have an affect,RF noise....etc.
Also,do our surge protectors cause any rf problems as well?
I know these may seem like Silly questions,but hey,,Im a girl,lol
I know nothing about electricity.
Anyone have any info on this? Much appriciated if So. Thanks!
 Post subject: good question
PostPosted: Fri Aug 27, 2004 9:13 am
hmmmm Tammy you got me there, But I remember doing something like this in my electrical engineering class at college 2 yrs ago, I joined to do a short course so I could fit my own shower as I hate paying out for someone else to do my own jobs, lol anyway..
I seem to remember a microphone is an energy converter that changes sound energy into electrical energy. A diaphragm in the microphone moves in and out in accordance with the compression and rarefaction of the atmosphere caused by sound waves. The diaphragm is connected to a device that causes current flow in proportion to the instantaneous pressure delivered to it. Many devices can perform this function. The particular device used in a given application depends on the characteristics desired, such as sensitivity, frequency response, impedance matching, power requirements, and ruggedness. The SENSITIVITY or EFFICIENCY of a microphone is usually expressed in terms of the electrical power level which the microphone delivers to a matched-impedance load compared to the sound level being converted. The sensitivity is rated in dB and must be as high as possible. A high microphone output requires less gain in the amplifiers used with the microphone. This keeps the effects of thermal noise, amplifier hum, and noise pickup at a minimum. For good quality sound reproduction, the electrical signal from the microphone must correspond in frequency content to the original sound waves. The microphone response should be uniform, or flat, within its frequency range and free from the electrical or mechanical generation of new frequencies. The impedance of a microphone is important in that it must be matched to the microphone cable and to the amplifier input as well as to the amplifier input load. Exact impedance matching is not always possible, especially in the case where the impedance of the microphone increases with an increase in frequency. A long microphone cable tends to seriously attenuate the high frequencies if the microphone impedance is high. This attenuation is caused by the increased capacitive action of the line at higher frequencies. If the microphone has a low impedance, a lower voltage is developed in the microphone, and more voltage is available at the load. Because many microphone lines used aboard ship are long, low- impedance microphones must be used to preserve a sufficiently high voltage level- over the required frequency range. Not sure if that helps any, sorry about blabbering on a little :)
and most importantly in answer to your question that I really didnt answer reading back lol, maybe this will help solve your problem thats if it is interference your getting through your 220 supply. Interference is not hard to find; it is actually difficult to avoid, especially in urban areas where the wireless revolution is well underway. By definition, interference originates from a source external to a signal path and produces undesired artifacts in the signal. A radio frequency, or RF, is loosely defined as being in that portion of the electromagnetic spectrum above audio (about 20 kHz) but below infrared (about 30 THz). Electromagnetic interference (EMI), is a broader term having the same basic meaning but without frequency limitations. Electromagnetic compatibility (EMC), is a term coming into more widespread use regarding issues of equipment electromagnetic emissions and susceptibility, especially because regulations now require all equipment sold in Europe to carry the CE mark.
Electromagnetic fields, such as radio and TV signals, travel through space (or air) at the speed of light, about 300,000,000 m/sec or 186,000 miles/sec. Because wavelength is the physical distance such a signal travels during a single cycle, as frequency increases wavelength decreases. For example, a 1 MHz AM radio signal has a wavelength of about 1,000 feet (305 m), but for a 100 MHz FM radio signal, it is about 10 feet (3 m), and for a 12 GHz DSS TV signal, only about an inch (25.4 mm). Any wire can accidentally become a good antenna if its length happens to be, say, the wavelength of a strong local FM station.
Sources of RF interference fall into two broad categories-intentional and unintentional. Intentional sources include AM, shortwave, FM, and TV broadcast transmitters as well as ham and CB transmitters, remote controls, wireless phones, cellular phones, commercial taxi/police/aircraft radios, microwave ovens, motion sensors, radar systems, and a myriad of medical and industrial RF devices.
Unintentional RF sources are most commonly devices that produce an electrical spark. Sparks are potent RF generators-before vacuum tubes, they were the heart of radio transmitters-that splatter energy over a wide frequency spectrum. Any wiring connected to the spark source not only conducts the RF but also acts as a transmitting antenna to radiate it. Common sparking sources include electric welders, brush-type motors, relays and switches of all kinds. Less obvious sources include arcing or corona discharge in power line insulators (common in seashore areas or under humid conditions), malfunctioning fluorescent or neon lighting and automobile spark plugs. Lightning is the ultimate spark and a well known producer of momentary interference to virtually anything electronic.
Other unintentional RF generators are devices that abruptly interrupt current flow using some form of electronic switching. The most common examples are light dimmers, fluorescent lights, TV or computer CRT displays and any piece of equipment using a switching power supply or "clock" oscillator (computers and other digital devices). The RFI source may be in the same room as your system or, worse yet, it may be a part of your system.
RFI symptoms The tolerance of equipment to RFI depends largely on how well it is designed. Generally, symptoms will appear when sufficient RF energy reaches an active device-IC, transistor, tube-inside the equipment. The energy can arrive in two ways: radiation or conduction. As it travels through the air, internal equipment wiring can act as a receiving antenna and deliver RF voltages directly to an active device. This is most common in equipment with plastic or wood enclosures that have no RF shielding ability. Because any wire can become a receiving antenna, RF energy can also be conducted into the equipment's active devices via any wire leaving or entering the equipment. Interference can also arrive via any wire coming into the building. Because power, telephone, CATV and even driveway intercom, landscape lighting, or outdoor loudspeaker lines also behave as outdoor antennas, they are often teeming with AM radio signals and other interference. The most troublesome sources, however, are frequently inside the building where the interference is distributed via the power wiring. At high frequencies, a building's power wiring behaves like a system of misterminated transmission lines gone berserk, reflecting RF energy back and forth throughout the power wiring until it is eventually absorbed or radiated. The RF does not just follow the green ground wire back to the earth ground rod and magically disappear.
RF power line noise is coupled through equipment power supplies into system ground conductors. Therefore, significant noise voltage will inevitably exist between the chassis grounds of any two devices in AC-powered systems, whether safety grounded or not. This is the dominant noise source in most systems, not noise picked up by cables as is so widely believed. When this noise flows in the shield of unbalanced signal cables, the voltage drop directly adds to the signal as shown in Figure 1.
Unbalanced interfaces generally use single-conductor shielded cable and two-contact connectors, such as the RCA or 1/4 inch phone for audio and the RCA or BNC for video signals. Remember that RS-232 data connections are also unbalanced. Sadly, most commercial equipment has never been tested for susceptibility to RF interference, whether arriving through the air or coupled to its inputs, outputs or such other outside world ports as its power cord. Of course, even well-designed equipment will misbehave if confronted with extreme levels of RF interference.
In audio systems, RFI symptoms range from actual demodulation of radio or CB (heard as music or voices) or TV signals (heard as buzz) to various noises or subtle distortions often described as a "veiled" or "grainy" quality in the audio. In video systems, symptoms from intentional transmitters usually cause herringbone patterns of some sort, and power-line related-sources usually cause bands of sparkles that slowly move vertically in the picture. In data connections, RFI generally causes otherwise unexplained behavior or crashes.
Stopping it There are two basic strategies to control RFI. The first prevents it from coupling in the first place by using filters or arc snubbers at the source, relocating equipment or rerouting cables, using signal path ground isolators or adding shielding or ferrite chokes to cables. The second filters out the RF, when possible, after it is coupled but before it reaches a sensitive active device in the equipment. The following recommendations can help prevent or cure most RFI problems.
Locate and treat the offending source. This applies primarily to unintentional power-line-related sources. Because these sources tend to generate both conducted and radiated wideband RFI, a portable AM radio tuned to a quiet frequency can be useful as a "sniffer" to locate an offending fluorescent light or dimmer, for example. Then, the offender can be replaced, repaired or a power-line RF filter installed.
Keep cables as short as possible, and pay attention to routing. A long cable not only increases power line common-impedance coupling (for unbalanced cables), but it also makes the cable a better antenna. Routing cables close to such ground planes as metal racks or concrete floors will reduce antenna effects. Never coil excess cable length.
Use cables with heavy gauge shields. Cables with foil and drain wire shields have much higher common-impedance coupling than those with braided copper shields, increasing power line noise coupling. Multiple shields offer no improvement unless they are connected at both ends.
Maintain good connections. Connectors left undisturbed for long periods can develop high-contact resistance or become metal oxide detectors for RF. Hum or other interference that changes when the connector is wiggled indicates a poor contact. Use a good commercial contact fluid and/or gold-plated connectors.
Do not add unnecessary grounds. It will generally increase circulating ground noise rather than reduce it. Attempting to short out RFI with heavy ground wires is generally ineffective. At RF, a wire's impedance is proportional to its length but nearly unaffected by its gauge. For example, 8 feet (2.4 m) of AWG #10 wire has an impedance of 22 V at 1 MHz (AM broadcast band). Using AWG #0000 wire (about 1/2 inch or 13 mm diameter) reduces it to only 18 V. Of course, never disconnect a safety ground or lightning protection ground to solve a problem-it is both illegal and dangerous.
Use ground isolators in problem signal paths. Ground isolators, whether transformer or optical types, couple signals while completely breaking electrical connections, which stops common-impedance coupling. Commercial isolators are available for audio, video and CATV signals. Because most types have limited bandwidth, they offer inherent RFI suppression. Beware that poor-quality units can often degrade signal quality.
Install RFI filters in the signal path. If the offending RF interference is more than about 20 MHz, ferrite clamshells, which are easily installed over the outside of a cable, can be effective. In most cases, they work best when placed on the cable at or near the receive end. If this is inadequate, or the frequency is lower (such as AM radio), you can add an RFI filter on the signal line. Schematics for unbalanced or balanced filters are shown in Figure 2. For mic line applications, L should be a miniature toroid to prevent possible magnetic hum pickup. If FM, TV or cell phone is the only interference, a small ferrite bead may suffice for L. In any case, C should be an NP0/C0G type ceramic disc with short leads. For severe AM radio interference, C may be increased to about 1,000 pF maximum. But dont you try this Tammy lol, just try and not lean your microphone on the supply, im sure that will help heaps ;)
PostPosted: Fri Aug 27, 2004 9:37 am
Very Very Good information.... Very Helpful.
This is keeper information!!! Thankyou!
PostPosted: Fri Aug 27, 2004 6:58 pm
Tammy, here's my 20 cents worth. Firstly, are you actually experiencing interference or are you just concerned it may happen with the config you have? You could check for it real easy by starting your recorder (without actually running any music into it) and take a look at the "flat line" waveform. Any interference will show up as ripple on the line. While doing this, you could move your various cords around and see if any positions make it better or worse. Make sure your cords are in good condition as any deterioration in the outer screening will allow interference in.
I wouldn't expect that you would have to fit suppressors to your mic but if it is needed, Rob's last sentence (in his thesis - LOL) about the ferrite beads and 1000 pf disc ceramic capacitor would be right on the money. Any more than 1000 pf will start to reduce the high frequency response of the mic. Anyway, you can always check if it's the mic by simply unplugging it. Good luck.
Those who bring sunshine to others cannot keep it from themselves :)
Snoopy
PostPosted: Sat Aug 28, 2004 12:15 am
OMG Rob... I think my brain went into meltdown reading all that!
PostPosted: Sat Aug 28, 2004 5:35 am
ok mene...so ur smart...but can u ride a horse?
haha
PostPosted: Mon Aug 30, 2004 9:29 pm
Non-Member
Well That's the main thing Kass! LOL!!!!
Nut! LOL......
Steve
PostPosted: Tue Aug 31, 2004 12:49 pm
i get so bored reading about things i already know about, such as the thingy's menephes1 mentioned above....yea rightttttt...lol...but i will keep all that in mind next time i need to change a light bulb...lol...i think my eyes crossed just reading is comments....gotta go lie down now....
Users browsing this forum: No registered users and 3793 guests
