Recording with CEP and Creative Audigy 2nx.
https://ksmo.us/forums/viewtopic.php?f=1&t=2420
Author:  Guest [ Sun Aug 15, 2004 2:43 pm ]
Post subject:  Recording with CEP and Creative Audigy 2nx.
I have tried to record a single track in Cool Edit Pro from the software sound generator in the multi track edit while playing another track.
However both sounds played, track & the sound source are recorded instead of sound from source or generator alone.
I have tried everything I can think of .. There seems not be any way to set it the way I want.. Being recorded sound of generator "only" without monitored second track.
Is it possible to achieve with Audigy 2nx?
Someone please help.. This is driving me nuts!
Author:  KJ Denndogg [ Thu Aug 19, 2004 9:23 pm ]
did you click the little "R" on the second track to record ? then click the record button >(bottom left) to play the first track and record the second.(Vocal) track . good luck :wink:
Author:  Atomic [ Thu Aug 19, 2004 10:26 pm ]
I think that's down to your soundcard settings, not CEP.
You need to make sure that your input is set specifically to the track you want to record, ie if its a vocal, you need to set your input to Mic. If you have it on mix, stereomix or whatuhear, its going to record the lot.
Author:  Guest [ Fri Aug 20, 2004 3:20 am ]
I am doing all that Denndogg.... Don't know why I still hear the actual music when I am only recording the vocals.. I am going to try Atomic's suggestion. I'll make sure I have this new soundcard configured correctly for what I am trying to do.. Thank you guys for attempting to answer my post... I'll let you know if I have any success with this.
Author:  Guest [ Fri Aug 20, 2004 4:38 am ]
It was the soundcard!! I fixed it.. I went in and changed some of the options.. Hurray!!!! :-) Thank you both, but thanks Atomic for steering me in the right direction.. I had contacted the people at Creative and they led me to believe that it was a problem with Cool Edit Pro.. So glad to finally have this resolved.. Now maybe I can actually produce a decent recording.. :D
Author:  cerealsinger [ Fri Aug 20, 2004 6:31 am ]
Yeah from ALOT of experience with software/hardware support people, I can tell you that you will never get any good help if you mention a 3rd party program, they will to 99% of the time always blame the other manufacturers software because "their product" is never at fault.
Author:  KJ Denndogg [ Fri Aug 20, 2004 8:21 am ]
WTG. Nightingale , good job. good advice Atomic !
