2nd system help
https://ksmo.us/forums/viewtopic.php?f=1&t=22896
Page 1 of 2
Author:  simpmech [ Sun Jan 08, 2012 9:17 am ]
Post subject:  2nd system help
Hey all, looking into putting another set up together. I really do not want to go active speakers, I am a fan of my separate amps, etc. Having said that, what are your thoughts on speakers, 800w, primarily used for music BUT occasionally used for Karaoke. I already have a set up we use for mostly Karaoke, so not to worried there. Thanks for your input.
**do not let cost be the determination here. But rather sound quality, durability etc. (I will be using subs with this set up)**
Author:  rickgood [ Sun Jan 08, 2012 10:22 am ]
Post subject:  Re: 2nd system help
Yamaha Stage Pass 500 - has reverb and compression settings for mics and sounds pretty good in most venues.
Author:  c. staley [ Sun Jan 08, 2012 11:10 am ]
I have to disagree on the active speakers - I've used them for the last 9 years with no problems. Previous to this I've had practically new amps die in the middle of a gig. At least with active, I don't have to stop. I've used the JBL EON (15") speakers.
Previously, I've used mackie amps and a number of different brands of speakers. If I was going to go back to amps, I'd also go back to using my Klipsch subwoofer. It has a very full and rich sound for vocals - much better than any other subwoofer I've ever used.
Author:  Lonman [ Sun Jan 08, 2012 11:52 am ]
I'd go active speakers personally for a second system. And if cost was no concern, the QSC KW152 for tops & QSC KW181 for the subs. Great for music system as well as karaoke. But they are spendy for the entire system, but very worth it for sound quality! If you were going to get separate components (amps, crossovers, speakers) with the same specs, you'd be paying as much if not more.
Author:  jerry12x [ Sun Jan 08, 2012 3:10 pm ]
Err...
Hmmm...
Eeee...
Errr....
No ... Can not work that one out.
Never heard subwoofer and vocals put together like that before.
Was it Lee Marvin's rig?
Author:  c. staley [ Sun Jan 08, 2012 3:42 pm ]
Err...
Hmmm...
Eeee...
Errr....
Not at all. It was hooked to a 1400w Mackie amp and I have another amp that is hooked to 2 Bose mid/highs. When used for karaoke, the Klipsch has a much "smoother" sound than the bose sub.
The bose sub however, is much better for a hard-driving, pounding "dance thump" for straight DJ jobs.
Author:  jerry12x [ Sun Jan 08, 2012 3:49 pm ]
No mate.
It is not which sub is better for vocals.
Vocals are not really in the frequency range of a sub.
Author:  earthling12357 [ Sun Jan 08, 2012 4:27 pm ]
jerry12x wrote:
No mate.
That's exactly what I would expect a singing dog to say.
Author:  c. staley [ Sun Jan 08, 2012 4:33 pm ]
jerry12x wrote:
No mate.
I'll tell you what: you come back to the U.S. and I'll hook up each one in succession for you to sing through. No other changes will be made other than which sub is hooked up. If you decide that there is no difference, or that the Bose is better, I'll buy your Ranch Dressing for the entire time you're here and even pay for your audiology test.
While it's true that most people don't sing in that range (except for Thurl Ravenscroft who is now dead), their voice (and the music) does have a different sound depending on the devices it goes through. The Klipsch doesn't have the same "pop" as the Bose - it seems to be a smoother (or "slower" action for lack of a better term) than the Bose.
There are distinct differences in the sound of these two. Even if none of the other components are changed at all.
Author:  jerry12x [ Sun Jan 08, 2012 4:34 pm ]
And that means?
Author:  jerry12x [ Sun Jan 08, 2012 4:41 pm ]
No Chip.
It can effect the tonal qualities of a song, but the vocals are not in sub frequencies.
It will effect the bass frequencies around the vocals.
Author:  jerry12x [ Sun Jan 08, 2012 4:43 pm ]
earthling what is your problem?
Author:  earthling12357 [ Sun Jan 08, 2012 4:44 pm ]
What selfrespecting dog would associate with a sub-woofer?
Author:  jerry12x [ Sun Jan 08, 2012 4:46 pm ]
Lol. Gotcha. :D
Author:  jerry12x [ Sun Jan 08, 2012 4:57 pm ]
Cumon Chip.
Concede and ship the ranch.
Author:  c. staley [ Sun Jan 08, 2012 5:03 pm ]
jerry12x wrote:
Cumon Chip.
Are you out?
I think it's a stalemate.... mate.... Because the tonal qualities (and reaction speed) DO in fact, make a difference on whether you'd want to sing with Klipsch or Bose subwoofer.... and which one "sounds better" for singing.
You get half the Ranch because I'll go 50/50 with you. I'll buy it, you ship it.
Author:  jerry12x [ Sun Jan 08, 2012 5:14 pm ]
I will go one better.
You ship it I eat it.
Vocals are not in the sub frequency range. On any system on planet earth.
On my world you would have stood a chance.
You are not of my world.
Tuff Titty.
Author:  c. staley [ Sun Jan 08, 2012 5:34 pm ]
I would need your address..... not the one to the group home this time.
and in "your world" you are required to surface periodically for medication.....
jerry12x wrote:
Tuff Titty.
Must be an "English Thing"..... like eating Spotted Dick....
Author:  earthling12357 [ Sun Jan 08, 2012 6:05 pm ]
Klipsch
SW-311 Subwoofer
FREQUENCY RESPONSE: 22Hz-120Hz ± 3dB
P-312W Subwoofer
FREQUENCY RESPONSE: 18-120Hz +/-3dB
http://www.listenhear.co.uk/general_acoustics.htm wrote:
Vocal frequency range
Soprano 250Hz - 1K
Contralto 200Hz - 700Hz
Baritone 110Hz - 425Hz
Bass 80Hz - 350Hz
I see some overlap there.
Author:  chrisavis [ Sun Jan 08, 2012 6:27 pm ]
I say we get Joe's scope out to prove it once and for all.....
