KARAOKE SCENE MAGAZINE ONLINE! - Online sound along with vocal using Alesis multimix4 usb Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Mon Nov 02, 2026 7:32 am
PostPosted: Thu Jun 02, 2011 10:18 am
Hi all,
New user here.
Just bought an Alesis Multimix4 usb mixer for my laptop.
I downloaded ASIO4 drivers and it works fine.
However, what I want to do is sing along with online karaoke tracks and record.
The online karaoke tracks are played by default sound card and the mic hooked up is via the USB mixer.
I am using a free software called Mixpad mixer from NCH.
When I select default sound card for recording, it only records karaoke and when I select ASIO, it only records my vocals from USB mixer.
How do I record both karaoke track from laptop's sound card along with vocal from USB mixer? :?
Thanks for suggestions.
PostPosted: Thu Jun 02, 2011 11:07 am
Mystery wrote:
Hi all,
New user here.
try setting the main default to the asio card in windows.
PostPosted: Thu Jun 02, 2011 12:27 pm
Been Liked: 17 times
Is it not necessary to send the audio from the online content through the mixer as well as the vocals to be able to record them simultaneously?
PostPosted: Thu Jun 02, 2011 12:34 pm
[quote="DannyG2006"]
try setting the main default to the asio card in windows.[/quote]
I tried that but then it still records one source not both.
hiteck,
I think that's what I have to do. :thinkin:
I'll send output from laptop to 1/4 input using stereo to RCA Y adapter on the mixer and then use ASIO for recording.
That may work.
PostPosted: Thu Jun 02, 2011 1:48 pm
[quote="hiteck"]Is it not necessary to send the audio from the online content through the mixer as well as the vocals to be able to record them simultaneously?[/quote]
I was hoping may be software can mix those two together for a final output.
I guess not... :?
PostPosted: Fri Jun 03, 2011 8:43 am
Mystery wrote:
hiteck,
That may work.
Did that work?
PostPosted: Fri Jun 03, 2011 6:00 pm
hiteck wrote:
Did that work?
Yes when I send the default sound card's output to LR input on the mixer, the USB sound device records all together but it used the only stereo input available in the mixer. :(
May be I need a bigger mixer.
But for now I can use this for vocals + online karaoke using this small mixer.
Thanks for the idea. I should have thought of it but my expectation was software could combine in the laptop but it doesn't. grrr...
Users browsing this forum: No registered users and 2221 guests
