KARAOKE SCENE MAGAZINE ONLINE! - EEEEEK! Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Mon Nov 02, 2026 7:37 am
Post new topic Reply to topic  [ 40 posts ]  Go to page 1, 2  Next
 Post subject: EEEEEK!
PostPosted: Tue Apr 19, 2011 2:30 pm
Got your attention? I want to start using a mouse. Anyone else use one? I want a shelf/platform that can house a mini mouse and be easy to pull off of my laptop pop up shelf. Any suggestions?
 Post subject: Re: EEEEEK!
PostPosted: Tue Apr 19, 2011 2:41 pm
Suggestions? for a mouse? Really?
I use a $10 wireless Logitech.
PostPosted: Tue Apr 19, 2011 2:49 pm
lol, Lonnie, every list has a best, worst and all the in betweens. That's the worst advise you've ever given me! I'm more interested in what people use as a shelf to hold the mouse.
PostPosted: Tue Apr 19, 2011 2:53 pm
Been Liked: 17 times
How about a rack mountable keyboard drawer?
SKB has the laptop tray for mounting on top of a slant top mixer, but would be nice to have a mouse pad attachment as well.
PostPosted: Tue Apr 19, 2011 3:11 pm
http://store.ergoguys.com/mouse-platfor ... KgodTTU0Hw
Thinking about this. I need it to come off the right side of my laptop pop up. I already have this
http://www.sweetwater.com/store/detail/SKBR104/
With this.
http://www.sweetwater.com/store/detail/SKBAV8/
I want to hook the mouse platform on the side. I'm just not for sure as the mouse platform won't be hooking onto a surface that's flat on both sides, the bottom of the laptop pop up has a half inch side on it.
PostPosted: Tue Apr 19, 2011 3:14 pm
No shelf for, just use the table and a mouse pad.
PostPosted: Tue Apr 19, 2011 3:20 pm
I see. Works for you, just not for me. Back to the mouse, does it ever fail?
PostPosted: Tue Apr 19, 2011 3:25 pm
http://www.topdjgear.com/rorerrdjlast.html
This is worth looking at but I already have my laptop holder. Wonder what bid they would accept?
PostPosted: Tue Apr 19, 2011 5:23 pm
Been Liked: 308 times
I'm confident you will find what you are looking for here:
http://www.dansdata.com/flitetech.htm
A strap-on for your mouse! :mrgreen:
KNOW THYSELF
PostPosted: Tue Apr 19, 2011 6:21 pm
Only when the battery dies. It's just one of those cheap laser mouse.
PostPosted: Tue Apr 19, 2011 6:43 pm
I wouldn't have believe it if I hadn't seen it!
PostPosted: Wed Apr 20, 2011 10:03 am
Is it a full sized mixer?
I have the exact same case and pop up. My mixer (Behringer XENYX X1204USB USB Mixer with Effects) has a smaller foot print so I modified the mounting brackets to give me a platform to the right of the mixer. It works great for me.
PostPosted: Wed Apr 20, 2011 11:18 am
Out of curiosity, why is it you want a mouse? Not feeling the trackpad control on your laptop?
When I first implemented a PC in my mobile rig.. 10 years ago.. I had to use a rack mounted PC because a laptop with enough ummph to run the TriceraSoft player was cost prohibitive for me at the time, and I already had plenty of desktop parts laying around.
Anyway.. I found a mouse to be a huge PITA, but a TRACKBALL worked great, and didn't require nearly as much real estate as a mouse and no mousepad or a smooth surface required.
I eventually picked up a rack mount, slide out keyboard that had an integrated trackball.. but if you've not ever tried a trackball, you may want to go to one of the office supply stores and check one out in their mouse display isle.
PostPosted: Wed Apr 20, 2011 11:33 am
This does kinda remind me of the guy that asked for reviews on tables. Not racks, TABLES.
I suggested the four-legged model :lol:
As for mice, I highly discourage the four-legged model :|
PostPosted: Wed Apr 20, 2011 11:59 am
I second the motion for a trackball. It's all I've used since first getting one years ago. I prefer the one with the ball on top to be moved by fingertips, not the one with the ball on the side for your thumb.
It takes a little getting used to at first, but it will grow on you. And you don't need much space, because it doesn't move.
KNOW THYSELF
PostPosted: Wed Apr 20, 2011 12:14 pm
I used a trackball for about a year, couldn't stand it. Definitely not for all.
PostPosted: Wed Apr 20, 2011 12:53 pm
Yeah, it's all about personal preference.. and even among the trackball crowd there is dissension.. I, for instance, like the trackball that is positioned for use with a thumb.. while others prefer the finger method.
I personally don't mind my Dell laptops trackpad at all.. but several of the other local KJ's and DJ's prefer to use an external mouse.
I just can't use those 'mini mice'.. my hands are just too big I guess.. and a full size mouse needs room to roam.. which means more desk space, or a shelf.
PostPosted: Wed Apr 20, 2011 1:28 pm
Just remember, whether it's trackball or mouse, keep the balls clean.
Abstract: Mouse Balls Available as FRU (Field Replacement Unit)
Mouse balls are now available as FRU. Therefore, if a mouse fails to operate or should it perform erratically, it may need a ball replacement. Because of the delicate nature of this procedure, replacement of mouse balls should only be attempted by properly trained personnel.
Before proceeding, determine the type of mouse balls by examining the underside of the mouse. Domestic balls will be larger and harder than foreign balls. Ball removal procedures differ depending upon manufacturer of the mouse. Foreign balls can be replaced using the pop-off method. Domestic balls are replaced using the twist-off method. Mouse balls are not usually static sensitive. However, excessive handling can result in sudden discharge. Upon completion of ball replacement, the mouse may be used immediately.
It is recommended that each replacer have a pair of spare balls for maintaining optimum customer satisfaction, and that any customer missing his balls should suspect local personnel of removing these necessary items.
To re-order, specify one of the following:
P/N 33F8462 - Domestic Mouse Balls
P/N 33F8461 - Foreign Mouse Balls
Dave's not here.
PostPosted: Wed Apr 20, 2011 1:42 pm
LOL!
Used to be much funnier though before optical mouse's became pretty much standard - no more balls to worry about keeping clean.
PostPosted: Wed Apr 20, 2011 1:43 pm
how do you even find something like that? :lol: :lol:
Users browsing this forum: No registered users and 2093 guests
