KARAOKE SCENE MAGAZINE ONLINE! - using 1/4 in jack into a speakan socket Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Mon Nov 02, 2026 1:26 pm
PostPosted: Thu Jan 13, 2011 8:14 am
Is there any way to use a 1/4 inch plug into a speakon socket?
Thanks,
Rick
PostPosted: Thu Jan 13, 2011 8:54 am
If it is not the Neutrik "Combo" socket that accepts both, you will need an adapter like this: http://tinyurl.com/4zvv3ds
Or just get a Speakon connector and replace the end of your cable. Easy enough to do.
PostPosted: Thu Jan 13, 2011 9:59 am
I went through a few of those adapters like Bazza recommended. They cut out on me about every 3 months. Then I got a pair of these guys:
http://www.google.com/products/catalog? ... Q8wIwADgK#
They have lasted me for 2 years and still going. I would highly recommend the single piece adapter over the one with the cord. Less to go wrong!
PostPosted: Thu Jan 13, 2011 10:13 am
I can attest to the fact that the ones that Topher uses are great. I also have several of these that I use on a regular basis. They have never failed at all. I got mine from a local dealer for about the same cost as the online place that Topher suggested.
PostPosted: Thu Jan 13, 2011 1:05 pm
I'll throw my hat in with Topher on this one. While either adapter will work, I've had far better success with the all-in-one rather than the pigtail design. The pigtail just adds two additional points of strain that aren't needed (at either end of that short little cable). In the few cases where I've needed a 1/4 to Speakon, I've used the all-in-one style.
DJ Tony
Users browsing this forum: No registered users and 2123 guests
