KARAOKE SCENE MAGAZINE ONLINE! - Connecting to dual screens? Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Mon Nov 02, 2026 5:35 pm
PostPosted: Sat Dec 04, 2010 9:14 am
I have a new show where they want me to connect to my monitor but also connect to their tv and show the words on both. I am not sure what I need to be able to do this. Do I need to purchase an additional video card? Is there anything else that is needed?
My laptop has s-video and vga. The tv I can connect via the s-video and the monitor via the vga however they don't currently both work when plugged in at the same time. What I would like to do is clone the monitor and tv screen while extending the laptop to the monitor/tv. Does that make sense?
PostPosted: Sat Dec 04, 2010 9:27 am
Use the vga out from your laptop and get one of these --> http://www.monoprice.com/products/produ ... 1&format=2
Set your desktop to extended mode and the above converter will send video to your monitor via vga and to the tv via s-video
PostPosted: Sat Dec 04, 2010 11:22 am
What kind of TV is it that you want to connect to. If it's a flat panel, it probably has a VGA input so all you would need to do is get a VGA Splitter like this:
http://www.radioshack.com/product/index ... Id=3521446
(there are also non-powered version of these that you could get much cheaper, however if you have any runs over 10ft I would recommend the powered splitter to avoid signal loss).
If their TV does not have a VGA input then a splitter like RLC recommended or one like this would work:
http://www.grandtec.com/products/video/untimateEZ.html
(that's the one I use, it's powered and works great, I've had all ports running at the same time in one case and it handled it well).
Hope that helps.
DJ Tony
PostPosted: Sat Dec 04, 2010 12:20 pm
You shouldn't need any extra adapters or converter boxes. Connect the tv via the Svideo and set the computer via the display properties to EXTENDED desktop. You have to make sure the TV is plugged in & turned on (and set to that input) in order for the computer to see it (in many cases). Once the computer is set, all you normally need to do is start your karaoke and when the words start, grab the lyrics box with the mouse & slide it over to the 2nd TV.
PostPosted: Sat Dec 04, 2010 4:17 pm
So Lonman, are you saying that a video signal can be sent simultaniously from both a vga output and a s-video output from the laptop to a monitor (vga) and a tv (s-video) with no converter box?
I didn't think that could be done. I was under the impression that only one video out source from a laptop could be used at a time.
PostPosted: Sun Dec 05, 2010 12:16 am
Lon, you're making an assumption that isn't valid. I have seen a number of laptops, mine included, that will not send video signal to both the VGA and S-Video outputs at the same time. Honestly, it takes a pretty heavy duty video card to do that because it basically becomes two separate video outputs (for a total of 3) due to the differences in refresh rate, resolution and such between the VGA signal and the NTSC signal.
DJ Tony
PostPosted: Sun Dec 05, 2010 4:31 am
I've used this one with great success:
http://www.monoprice.com/products/produ ... largeimage
PostPosted: Sun Dec 05, 2010 7:50 am
I tried one like that.
It worked fine one night, then one of the monitors started ghosting.
I ended up getting one like this.
http://cgi.ebay.com/Laptop-PC-4-LCD-VGA ... 1665wt_897
PostPosted: Sun Dec 05, 2010 9:17 am
Been Liked: 173 times
Decide which video out(VGA or Svideo) you want to use, you only need one. Then use the appropriate Y splitter, or converter box to distribute the video signal from that video out. This depends on the available video ins on both monitors/tvs. If any monitor/tv is a long run, you may need to use some type of video amplification. There are many inexpensive gadgets out there to solve just about any a/v need.
PostPosted: Sun Dec 05, 2010 10:44 am
I did not mention using both VGA & S-Video simultaneously, being a laptop I would use the laptop screen as the host monitor, then the S-Video extends to the TV via an S-Video connection (may need to manually adjusted in display properties).
I did misunderstand that in the OP that he wanted to use both VGA AND S-Video outputs. That i've never tried.
PostPosted: Mon Dec 06, 2010 8:57 am
I use this for Both VGA and RCA Or Svideo simultainiously (sp)
run a tv and a Vga same time.
PostPosted: Wed Dec 08, 2010 6:41 am
I use one of these guys:
http://www.google.com/products/catalog? ... H0Q8wIwAA#
Just hook that up to the S-Video and use your computer's dual screen function. Split an RCA out of the adapter, good to go.
Total cost: $1.00 plus shipping.
PostPosted: Thu Dec 09, 2010 9:16 am
he needs to go VGA and S Video at the same time.
that lil connection above I paid $24.00 at Radio Shack before I found out about Monoprice dot com right here in this forum. a few years back.
Users browsing this forum: No registered users and 1691 guests
