KARAOKE SCENE MAGAZINE ONLINE! - Connecting a Philips SWA2080W/27 Black Universal Microphone to mixer Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Wed Nov 04, 2026 8:11 am
PostPosted: Tue Oct 12, 2010 8:20 pm
Hello,
While my shure 58 mic is being shipped I wanted to see if the other cheap Philips universal microphone canbe connected to my YAMAHA MW10c mixer..
I mic has 1/4 inch adapter and it goes into the mic ports on the mixer but the sound does not seem to pass through the mic.
Is it even possible to use the universal mic with the yahama mixer??
Here is a picture of the mic that I am trying to connect
https://www.honeydohardware.com/comersu ... duct=83634
Here is a picture of the mixer
http://www.samedaymusic.com/product--YAMMW10C
Vaydee
PostPosted: Tue Oct 12, 2010 10:39 pm
it should work. did you perhaps plug it into the insert instead of the line input?
use the 1/4" closest to the xlr input.
PostPosted: Wed Oct 13, 2010 1:58 am
It's possible the mixer does not like the unbalanced jack - you could try to use an XLR adapter
http://www.bhphotovideo.com/c/product/1 ... 3_Pin.html
Although this one I do not believe is a true converter/transformer. If like stated you aren't in the correct jack, then it won't work at all, if you are in the 'line' jack and still not getting sound (I am assuming you have the gain & level control turned up on the channel), then try to stick it into one of the stereo channel 7/8 or 9/10 MONO jack. If this still doesn't work, you possibly have a defective mic.
PostPosted: Wed Oct 13, 2010 6:57 am
I've plugged the exact same mic into my Behringer mixer and it works fine, though
the output level is low - needed all levels turned way up.
PostPosted: Wed Oct 13, 2010 2:59 pm
Thanks gurus for the quick replies. I will give it a try again.
PostPosted: Wed Oct 13, 2010 4:44 pm
You may find this article helpful:
http://www.suite101.com/content/how-to- ... ut-a261049
DJ Tony
Users browsing this forum: No registered users and 2790 guests
