KARAOKE SCENE MAGAZINE ONLINE! - regulators/limiters Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Tue Nov 03, 2026 8:49 am
 Post subject: regulators/limiters
PostPosted: Tue Aug 31, 2010 4:30 am
Hi
Is there anything you can buy that can limit the output from the amplifier in to your speakers.
for example i have speakers that are 250 watt continuous but an amplifier the puts out 450 watt per channel, so clearly don't want to fry them by overloading them, is there a solution.
 Post subject: Re: regulators/limiters
PostPosted: Tue Aug 31, 2010 5:21 am
smiler01 @ Tue Aug 31, 2010 7:30 am wrote:
Hi
Actually if the speaker accepts 250w continuous, that means 500w program. That matches your 450w/channel almost perfectly.
PostPosted: Tue Aug 31, 2010 9:55 am
Your amp should be fine for those speakers. Which model are the speakers & amp? Usually you want to try to match the amp to the speakers PROGRAM power rating. In this case, the speaker is most likely rated 250 RMS(Continuous)/500 PROGRAM/1000 PEAK.
Users browsing this forum: No registered users and 2100 guests
