[ 8 posts ] |
Lone Wolf
Posted: Mon Aug 02, 2010 9:40 am |
Joined: Mon May 28, 2007 10:11 am Posts: 1832 Location: TX Been Liked: 59 times
I have been re-ripping all my discs to 320 as some were at 128 and others at 192 and got to thinking about using a program called MP3 Gain to make the volumes on all the MP3's the same volume, I was thinking of using 90db which is just about as loud as you want to get before you get track clipping.
Does anyone else do this? Is it a good Idea, I thought so because then I wouldn't be jumping at the knobs trying to turn up or down the volume depending on the song.
Let me here your thoughts.
_________________ I like everyone when I first meet them. If you don't like me that's not my problem it's YOURS! A stranger is a friend you haven't met yet
Alex
Posted: Mon Aug 02, 2010 9:46 am |
While you're putting all the work of re-ripping your discs into it anyway, why not? It's just one more added step and saves you a lot of headache later on. So go for it!
Micky
Posted: Mon Aug 02, 2010 10:00 am |
I would too and 0db is the saturation point
letitrip
Posted: Mon Aug 02, 2010 10:06 am |
I haven't gone through most of my older stuff, but as I add new tracks I have been normalizing them, yes. The unfortunate thing is the levels still vary greatly because some tracks are heavily compressed when they're recorded and the result is that the transient peaks are not that much higher in level than the rest of the program material. Conversely, there are plenty of tracks that have a much wider crest factor (ratio of average levels to peak levels) where most of the track is quiet but then the peaks are pretty severe. Normalizing results in these tracks sounding quieter.
So since I have the luxury of compression on every channel on my console, I do run stereo compression on the Karaoke Tracks channel. It helps some but still isn't' perfect and has to be tweaked or bypassed for some songs (definitely not a set it and forget it item).
Honestly I'm thinking if I really wanted to get this under control, I'd need to compress some of the songs with the wider crest factor (so first I'd have to locate them) and then normalize after that.
_________________ DJ Tony
twansenne
Posted: Mon Aug 02, 2010 10:25 am |
Lone Wolf @ Mon Aug 02, 2010 11:40 am wrote: Does anyone else do this? Is it a good Idea, I thought so because then I wouldn't be jumping at the knobs trying to turn up or down the volume depending on the song.
Wish I would have normalized from the beginning, but didn't. If I ever have to re-rip my CDGs, I definatly will.
BTW...Rip at 240+, for a lil better sound, hard drives are cheap if you need more space.
Micky
Posted: Mon Aug 02, 2010 2:18 pm |
twansenne @ Mon Aug 02, 2010 1:25 pm wrote: Lone Wolf @ Mon Aug 02, 2010 11:40 am wrote: Does anyone else do this? Is it a good Idea, I thought so because then I wouldn't be jumping at the knobs trying to turn up or down the volume depending on the song.
Let me here your thoughts. Wish I would have normalized from the beginning, but didn't. If I ever have to re-rip my CDGs, I definatly will. BTW...Rip at 240+, for a lil better sound, hard drives are cheap if you need more space.
And with a Lame encoder
RLC
Posted: Mon Aug 02, 2010 2:29 pm |
I have run all my tracks through Mp3Gain. I used the default setting of 89db.
It certainly does help but as letitrip stated it is by no means a set and forget thing.
Lone Wolf
Posted: Tue Aug 03, 2010 7:30 am |
twansenne @ Mon Aug 02, 2010 12:25 pm wrote: Lone Wolf @ Mon Aug 02, 2010 11:40 am wrote: Does anyone else do this? Is it a good Idea, I thought so because then I wouldn't be jumping at the knobs trying to turn up or down the volume depending on the song.
Why at 240 I'm re-ripping at 320
You don't have to re-rip them if they are unzipped you just need to normalize them the only reason I'm re-ripping them as they were at 128-192 to begin with and when I get a manu's set done I normalize them.
Thanks for all the input Y'all
[ 8 posts ] |
Users browsing this forum: DannyG2006 and 1860 guests |
