hiteck
Posted: Thu Jul 29, 2010 4:45 pm |
Joined: Sun Jun 06, 2010 10:39 am Posts: 884 Location: Tx Been Liked: 17 times
I'm currently using CDG's with my home setup and am looking for a better way to manage my song book. Currently I have everything in a excel spreadsheet (about 2500 songs) and when I buy a new disc I have to update and re-sort 2 versions Sorted by Title and by Artist.
I've been looking for a song book creator online but everything seems to want to read from a hard drive to generate the list. I'm still using CDG's so currently haven't backed up anything or shifted to mp3 format.
Does anyone know of a song book creator that I can import say a comma delimited file into and then use to maintain my library and different sorts?
BruceFan4Life
Posted: Thu Jul 29, 2010 5:03 pm |
| Super Duper Poster |
Joined: Wed May 18, 2005 10:03 pm Posts: 2674 Location: Jersey Been Liked: 160 times
KJ Pro is a simple to use karaoke songbook maker. Just click pn each disc that you own and the software does the rest
hiteck
Posted: Thu Jul 29, 2010 6:12 pm |
That's a little more than I wanted to spend plus it looks like I'd have to pay for updates. I already have all of my songs in an excel spreadsheet, and don't mind adding them per disc as I buy them just trying to get a two column layout and easy sort without having to move my #A-Z breaks and re-arranging headings each time I add to it.
Maybe I should just create a mysql database and import my csv file. Then I could write a php script that will allow me to add my new stuff and then I could sort however and then just work on my output formatting.
DannyG2006
Posted: Thu Jul 29, 2010 6:24 pm |
Fast Tracks is a great songbook program. Plus for a fee you get lifetime updates. The Basic costs$80. www.karaokeware.com
classickaraoke
Posted: Fri Jul 30, 2010 7:29 am |
Joined: Thu Apr 10, 2008 2:12 pm Posts: 299 Been Liked: 0 time
Lone Wolf
Posted: Fri Jul 30, 2010 7:47 am |
Joined: Mon May 28, 2007 10:11 am Posts: 1832 Location: TX Been Liked: 59 times
Although I don't use it Airwer will do what you want although it costs $100 for the program and all updates are free. All you have to do is check mark the discs you have and it will do the rest.
Can be found at www.airwer.com
_________________ I like everyone when I first meet them. If you don't like me that's not my problem it's YOURS! A stranger is a friend you haven't met yet
BigJer
Posted: Fri Jul 30, 2010 8:08 am |
Joined: Fri Aug 28, 2009 10:42 pm Posts: 1064 Been Liked: 92 times
I've used KJ Pro for a long time, through several version updates. Unfortunately, they don't seem to keep up on the updates anymore or else the software is getting so screwed up that the update part no long works properly for me. The basic program still works and has a lot of music in it already and you can manually update.
Next time I buy one, I'll get the Fast Tracks or whatever it is that works with Compuhost.
BruceFan4Life
Posted: Fri Jul 30, 2010 8:15 am |
BigJer @ July 30th 2010, 11:08 am wrote: I've used KJ Pro for a long time, through several version updates. Unfortunately, they don't seem to keep up on the updates anymore or else the software is getting so screwed up that the update part no long works properly for me. The basic program still works and has a lot of music in it already and you can manually update.
Maybe you need to re install the program BigJer. Mine still works great...except for the numerous Sound Choice errors over the years. It seems like someone from Sound Choice would give KJ Pro the right songs but in the wrong order.
TopherM
Posted: Fri Jul 30, 2010 8:46 am |
Over the years, I have used Excel, the Airwer Songlist Creator, KJ Pro, and FastTracks.
KJ Pro is definitely the best pure songbook creator of the three.
I did not care for Airwer at all.
FastTracks is not as good as KJ Pro, but it integrates with CompuHost and CDGRip very very well. Basically, you enter your discs into FastTracks, burn the disc with CDGRip and it automatically names the tracks in the exact format CompuHost uses.
So, if you use CompuHost, get FastTracks. It will save you WEEKS of setup on your digital library. I think lifetime updates are only like $30.00 extra, but worth every penny.
If you do not use CompuHost, go with KJPro!!
I wouldn't buy the Airwer Songbook Creator, it just is not as robust as either of the other programs.
_________________ C Mc
PyrateSilly
Posted: Fri Jul 30, 2010 11:28 am |
Joined: Tue Apr 27, 2010 3:46 pm Posts: 107 Been Liked: 11 times
After looking at alot of book programs and doing it myself with excel we went with Fast Tracks. I like it alot. You do not have to rip the discs, you can just click the disc and add. You can also export to csv file or import the csv file so there is less clicking to start. There are also several ways that you can print the book out.
I do the Fast Tracks then export and look at the listings. Do sortings all kinds of ways and fix ones that are wrong (i.e. song name, singer name, etc.). I fix it both in the program and in the file. Since I have put the cd+g's on the hard drive I will also fix the titles in that so that when I want to redo the book and start over with a new book I don't have to fix them all over again. (does that make sense?) The program itself isn't really to blame for the wrong listings, since it's the manu that gives that info.
Alan B
Posted: Sun Aug 01, 2010 2:22 pm |
I also use FastTracks. It is awesome. Probably the best. And if you have CompuHost, the integration is seemless. A great combination but either one can be used alone.
jclaydon
Posted: Mon Aug 02, 2010 8:16 am |
I also use fastracks. Out of all the software I have used, it is the easiest. My only complaint is there aren't enought editing features. I mean how hard could it be to program to be able to select multiple items, even for something as simple as pushing the delete key. *sigh*
DannyG2006
Posted: Mon Aug 02, 2010 8:41 am |
jclaydon @ Mon Aug 02, 2010 11:16 am wrote: I also use fastracks. Out of all the software I have used, it is the easiest. My only complaint is there aren't enought editing features. I mean how hard could it be to program to be able to select multiple items, even for something as simple as pushing the delete key. *sigh*
Do you mean to edit a field. They have that right click on the item you want to change and go to multiedit.
jclaydon
Posted: Mon Aug 02, 2010 8:47 pm |
DannyG2006 @ Mon Aug 02, 2010 8:41 am wrote: jclaydon @ Mon Aug 02, 2010 11:16 am wrote: I also use fastracks. Out of all the software I have used, it is the easiest. My only complaint is there aren't enought editing features. I mean how hard could it be to program to be able to select multiple items, even for something as simple as pushing the delete key. *sigh*
-James Do you mean to edit a field. They have that right click on the item you want to change and go to multiedit.
No, I am talking about things like deleting multiple tracks. Or being able to edit ONLY the selected tracks instead of ALL of the tracks that match the search criteria. The "multi-edit" feature has a limited use, in my opinion.
The weird thing is I can't seem to remember what exactly I was trying to do where the function wouldn't work.
edit:I just remembered I was trying to change the "genre" settings for about 300 tracks, which I had to do one disc at a time.. PITA!
eben
Posted: Tue Aug 03, 2010 1:49 am |
jclaydon @ Mon Aug 02, 2010 8:47 pm wrote: DannyG2006 @ Mon Aug 02, 2010 8:41 am wrote: jclaydon @ Mon Aug 02, 2010 11:16 am wrote: I also use fastracks. Out of all the software I have used, it is the easiest. My only complaint is there aren't enought editing features. I mean how hard could it be to program to be able to select multiple items, even for something as simple as pushing the delete key. *sigh*
-James Do you mean to edit a field. They have that right click on the item you want to change and go to multiedit. No, I am talking about things like deleting multiple tracks. Or being able to edit ONLY the selected tracks instead of ALL of the tracks that match the search criteria. The "multi-edit" feature has a limited use, in my opinion. The weird thing is I can't seem to remember what exactly I was trying to do where the function wouldn't work. edit:I just remembered I was trying to change the "genre" settings for about 300 tracks, which I had to do one disc at a time.. PITA!
I totally agree with you. Love using the Fasttrack but that is one major short coming. All they need to do is to allow control click to select multiple songs and change one field on all the songs. It would be so huge time saver if they allowed that.
mrgadget01
Posted: Tue Aug 03, 2010 10:40 am |
Joined: Thu Aug 13, 2009 11:03 am Posts: 136 Been Liked: 1 time
Try Pilot Song Book Creator. If you like it, it's only $39. You can import from your song files, CSV, or from discs. You can format anyway you want. There are a host of print out formats. It will even allow you to synchronize the song names of the files with the song names in the program such as if you globally change all " The's" to " , The" and the end.
Check out the free demo. You can find the link on my blog:
http://www.nwohiokaraoke.blogspot.com
_________________ Join Us on Facebook!
NW Ohio Karaoke
theCheese
Posted: Tue Aug 03, 2010 10:57 am |
| Advanced Poster |
Joined: Mon Aug 02, 2010 11:02 am Posts: 485 Location: third stone from the sun Been Liked: 2 times
I like KJPro.. it makes nice looking books, and is easy to use.
Great for quickly building a book for an existing collection, and easy to add new discs.
You don't really need to buy the future updates, either.. you can always manually enter new discs as you get them.
c. staley
Posted: Tue Aug 03, 2010 4:56 pm |
| Extreme Poster |
Joined: Thu Jun 06, 2002 7:26 am Posts: 4839 Location: In your head rent-free Been Liked: 583 times
Books?..... c'mon it's 2010.... get with the program....
use a kiosk and get rid of books....
I haven't used a printed paper book in 6 years...
(kills muchn fewer trees you know.)
hiteck
Posted: Tue Aug 03, 2010 5:38 pm |
c. staley @ Tue Aug 03, 2010 6:56 pm wrote: Books?..... c'mon it's 2010.... get with the program....
My request for a better way was for my home use....I'm still using a dual CDG player and CDG's so I don't see spending the money on a kiosk. I'm only doing one book so not really having that much effect on the environment, I'm just looking for a better way to organize my selections for private/family fun.
mrgadget01
Posted: Wed Aug 04, 2010 4:03 am |
For home use, use Excel and sort by whatever column you want. Will print out pretty well. If you have Access, you could use that too and maybe find a few better printouts. Otherwise, Excel it the way to go for home use.
I didn't see where you mentioned how many discs you had. You can cut and paste info for the discs from most website lists to add to your database.
NW Ohio Karaoke
Users browsing this forum: DannyG2006 and 1861 guests |
