S115V Speakon Connection Help
https://ksmo.us/forums/viewtopic.php?f=1&t=19848
Author:  huskysglare [ Wed Jul 28, 2010 11:59 am ]
Post subject:  S115V Speakon Connection Help
I'd just gotten my new S115V yamaha speakers and there are 2 Speakon in the back. Which one do i use to plug into my AMP? The left or the right?
Author:  jamkaraoke [ Wed Jul 28, 2010 12:14 pm ]
Post subject:  Re: S115V Speakon Connection Help
Either one --I believe they are just parralle hook up for daisy chaining speakers together?
Connections on these loudspeakers are dual Neutrik Speakon® ¼ jacks for the highest possible strength and current capacity. Two of each connector makes it easy to "daisy chain," or add speakers.
Author:  TopherM [ Wed Jul 28, 2010 1:07 pm ]
Jam's correct. Either works the same....there are just two in case you want to do a parallel configeration.
Author:  huskysglare [ Wed Jul 28, 2010 9:42 pm ]
Thanks guys. Much appreciated.
Author:  Bazza [ Thu Jul 29, 2010 11:44 am ]
And you would never use more than ONE of the four connectors (2-Speakon, 2-1/4inch) as an input....and ONE as an output to another speaker.
You would never, for example, run two cables from two different amps (or one amp for that matter) to the same speaker or run from a speaker to another amps input. This should go without saying, but after reading the other fried speaker thread I thought I would mention it. :lol:
Author:  Lonman [ Thu Jul 29, 2010 11:46 am ]
No you would never run two amps to 1 speaker - unless it is specifically wired for a bi-amp setup, which the S115V is not. You can run 1 amp to the speaker then daisy chain from the speaker to another speaker.
