[ 14 posts ] |
kameragurl
Posted: Mon Jul 05, 2010 1:50 pm |
| Advanced Poster |
Joined: Fri Nov 02, 2007 6:13 am Posts: 277 Location: Texas Been Liked: 1 time
Hi. I converted to digital. From Computor to module is S video. From RF modulator ro moniotor is cable. Set up says 1 on computor and 2 on tv. No words show up on screen. What do you suggest might be a solution?
Manobeer
Posted: Mon Jul 05, 2010 1:57 pm |
Joined: Thu Mar 11, 2010 11:16 pm Posts: 179 Been Liked: 0 time
kameragurl @ Mon Jul 05, 2010 1:50 pm wrote: Hi. I converted to digital. From Computor to module is S video. From RF modulator ro moniotor is cable. Set up says 1 on computor and 2 on tv. No words show up on screen. What do you suggest might be a solution?
Is desk top extended?
What software are you using?
When you say monitor shows the number two, you are saying that windows detected and identified...correct?
Manobeer
Posted: Mon Jul 05, 2010 2:03 pm |
Still would like to know what software you are using to play the file.
Also, if computer has Svid out why would you need RF modulator?
Without getting too techy...
Depending on software, when playing a karaoke file a small window will open up(maybe on computer 1 screen). You need to slide it over to screen 2 and expand it.
kameragurl
Posted: Mon Jul 05, 2010 2:08 pm |
| Advanced Poster |
How do you slide it over? Don't know how.
kameragurl
Posted: Mon Jul 05, 2010 2:18 pm |
| Advanced Poster |
kameragurl @ Mon Jul 05, 2010 4:08 pm wrote: How do you slide it over? Don't know how.
Running Rox Box.
Manobeer
Posted: Mon Jul 05, 2010 2:19 pm |
kameragurl @ Mon Jul 05, 2010 2:08 pm wrote: How do you slide it over? Don't know how. Do you see the window with lyrics in it on screen 1?
Use mouse to DRAG it over edge of screen 1 onto screen 2.
Drag by placing cursor over object, press and hold left mouse button while moving mouse to desired location.
kameragurl
Posted: Mon Jul 05, 2010 2:40 pm |
| Advanced Poster |
Manobeer @ Mon Jul 05, 2010 4:19 pm wrote: kameragurl @ Mon Jul 05, 2010 2:08 pm wrote: How do you slide it over? Don't know how. Do you see the window with lyrics in it on screen 1? Use mouse to DRAG it over edge of screen 1 onto screen 2. Drag by placing cursor over object, press and hold left mouse button while moving mouse to desired location.
The computor screen was blank, the tv sreen had microsoft screen saver. The tv has cable input only. That why we had to have the RF Modulator.
DannyG2006
Posted: Mon Jul 05, 2010 2:50 pm |
You might want to check out a different player. I use Justkaraoke and it finds the 2nd monitor on it's own. Only costs $34.95 has a filler player that you set and forget. Also allows you to enter as many songs into a single singer's que. It is just one of a few reasons I switched from RoxBox to JustKaraoke.
kameragurl
Posted: Mon Jul 05, 2010 3:00 pm |
| Advanced Poster |
DannyG2006 @ Mon Jul 05, 2010 4:50 pm wrote: You might want to check out a different player. I use Justkaraoke and it finds the 2nd monitor on it's own. Only costs $34.95 has a filler player that you set and forget. Also allows you to enter as many songs into a single singer's que. It is just one of a few reasons I switched from RoxBox to JustKaraoke.
Thank you for the info. I think we will stick with what we have for right now. Still sort of in the learning process. Thank you again.
DJMojo
Posted: Tue Jul 06, 2010 3:36 am |
Joined: Sat Dec 29, 2007 8:08 am Posts: 250 Location: The Great State of Tennessee Been Liked: 1 time
Kameragurl, I thought you were anti-computer? What happened?
Mojo
_________________ "It looks just like a Telefunken U47 !"
hiteck
Posted: Tue Jul 06, 2010 4:25 am |
Joined: Sun Jun 06, 2010 10:39 am Posts: 884 Location: Tx Been Liked: 17 times
DJMojo @ Tue Jul 06, 2010 5:36 am wrote: Kameragurl, I thought you were anti-computer? What happened?
Mojo
Resistance is futile?
kameragurl
Posted: Fri Jul 09, 2010 5:35 am |
| Advanced Poster |
Mojo
I heard it was ok just so I had things registered.
Bazza
Posted: Fri Jul 09, 2010 7:48 am |
First things first before you even start your hosting software.
If you move your mouse off the main screen to the right, do you see your mouse pointer appear on the second monitor?
If so, then it is a problem with your hosting software. If not, it's a windows/cabling issue.
[ 14 posts ] |
Users browsing this forum: No registered users and 2223 guests |
