KARAOKE SCENE MAGAZINE ONLINE! - Monitor 2 Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Wed Nov 04, 2026 5:42 am
 Post subject: Monitor 2
PostPosted: Mon Jul 05, 2010 1:50 pm
Hi. I converted to digital. From Computor to module is S video. From RF modulator ro moniotor is cable. Set up says 1 on computor and 2 on tv. No words show up on screen. What do you suggest might be a solution?
 Post subject: Re: Monitor 2
PostPosted: Mon Jul 05, 2010 1:57 pm
Is desk top extended?
What software are you using?
When you say monitor shows the number two, you are saying that windows detected and identified...correct?
PostPosted: Mon Jul 05, 2010 1:58 pm
yes, that is correct.
PostPosted: Mon Jul 05, 2010 2:03 pm
Still would like to know what software you are using to play the file.
Also, if computer has Svid out why would you need RF modulator?
Without getting too techy...
Depending on software, when playing a karaoke file a small window will open up(maybe on computer 1 screen). You need to slide it over to screen 2 and expand it.
PostPosted: Mon Jul 05, 2010 2:08 pm
How do you slide it over? Don't know how.
PostPosted: Mon Jul 05, 2010 2:18 pm
Running Rox Box.
PostPosted: Mon Jul 05, 2010 2:19 pm
Do you see the window with lyrics in it on screen 1?
Use mouse to DRAG it over edge of screen 1 onto screen 2.
Drag by placing cursor over object, press and hold left mouse button while moving mouse to desired location.
PostPosted: Mon Jul 05, 2010 2:40 pm
The computor screen was blank, the tv sreen had microsoft screen saver. The tv has cable input only. That why we had to have the RF Modulator.
PostPosted: Mon Jul 05, 2010 2:50 pm
You might want to check out a different player. I use Justkaraoke and it finds the 2nd monitor on it's own. Only costs $34.95 has a filler player that you set and forget. Also allows you to enter as many songs into a single singer's que. It is just one of a few reasons I switched from RoxBox to JustKaraoke.
PostPosted: Mon Jul 05, 2010 3:00 pm
Thank you for the info. I think we will stick with what we have for right now. Still sort of in the learning process. Thank you again.
PostPosted: Tue Jul 06, 2010 3:36 am
Kameragurl, I thought you were anti-computer? What happened?
Mojo
"It looks just like a Telefunken U47 !"
PostPosted: Tue Jul 06, 2010 4:25 am
Been Liked: 17 times
Mojo
Resistance is futile?
PostPosted: Fri Jul 09, 2010 5:35 am
Mojo
I heard it was ok just so I had things registered.
PostPosted: Fri Jul 09, 2010 7:48 am
First things first before you even start your hosting software.
If you move your mouse off the main screen to the right, do you see your mouse pointer appear on the second monitor?
If so, then it is a problem with your hosting software. If not, it's a windows/cabling issue.
Users browsing this forum: No registered users and 2210 guests
