[ 20 posts ] |
hiteck
Posted: Sun Jun 27, 2010 3:54 am |
Joined: Sun Jun 06, 2010 10:39 am Posts: 884 Location: Tx Been Liked: 17 times
Is Key and Pitch the same thing?
My CDG player has a pitch slider. I just purchased another piece of equipment (mainly for the a/v switch and multiplex feature) and it has Key changes flat and sharp.
Was just curious is they were the same similar or ??
DannyG2006
Posted: Sun Jun 27, 2010 4:19 am |
I'd personally use the keychanger on the other piece of equipment than either that is built into the CDG player as most of those effect the tempo as well as the pitch.
hiteck
Posted: Sun Jun 27, 2010 4:53 am |
Thanks DannyG2006 the Pitch slider did seem to effect the tempo some, but wasn't sure. I didn't know if typically you had key, tempo and then pitch was a slight combination of the two.
DannyG2006
Posted: Sun Jun 27, 2010 4:56 am |
The advantage of using the other piece of equipment is that you can change the key on any of the sources that are running through it.
JoeChartreuse
Posted: Sun Jun 27, 2010 10:10 pm |
In answer to the original question: The main difference between Pitch Control and Digital Keychange is that while Pitch Control will also change tempo - like it or not-( and possibly cause distortion), Digital Key Control will not. ( well, usually no distortion within at least 3 steps either way, anyway.)
Also, DKC is a bit more precise ( usually in 1/2 octave steps), while PC requires more guess work. If you have no desire for tempo change, DKC is usually the best bet.
hiteck
Posted: Mon Jun 28, 2010 5:05 am |
ggardein
Posted: Mon Jun 28, 2010 4:14 pm |
| Advanced Poster |
Joined: Thu Mar 22, 2007 6:12 pm Posts: 339 Location: D.C. Been Liked: 3 times
JoeChartreuse @ Mon Jun 28, 2010 1:10 am wrote: In answer to the original question: The main difference between Pitch Control and Digital Keychange is that while Pitch Control will also change tempo - like it or not-( and possibly cause distortion), Digital Key Control will not. ( well, usually no distortion within at least 3 steps either way, anyway.)
wow, 1/2 octave steps equal 4 tones.....those are big jumps.....
JoeChartreuse
Posted: Mon Jun 28, 2010 11:37 pm |
nobodyhome @ Mon Jun 28, 2010 7:14 pm wrote: JoeChartreuse @ Mon Jun 28, 2010 1:10 am wrote: In answer to the original question: The main difference between Pitch Control and Digital Keychange is that while Pitch Control will also change tempo - like it or not-( and possibly cause distortion), Digital Key Control will not. ( well, usually no distortion within at least 3 steps either way, anyway.)
Also, DKC is a bit more precise ( usually in 1/2 octave steps), while PC requires more guess work. If you have no desire for tempo change, DKC is usually the best bet. wow, 1/2 octave steps equal 4 tones.....those are big jumps.....
You are right, and that's one disadvantage of DKC vs Pitch, but at least you know where you are, as oopposed to pitch, which you kinda have to guess. Plus pitch changes tempo- lower is slower, higher is faster- without any control. Prefer DHC.
Babs
Posted: Mon Jun 28, 2010 11:56 pm |
This is sort of on the same lines of the discussion -
I had a guy come in the other night and ask me if I could adjust by semitones. I didn't have a clue what a semitone was. I explained that I could adjust the key or tempo if he'd like. He couldn't explain what one was so when I got home I looked it up. Semitone is a half step.
hiteck
Posted: Tue Jun 29, 2010 4:09 am |
According to some info I found on this unit (VocoPro KC-300 Pro), there is a 12-step DSP Key Controller to raise and lower the natural musical key by 2 full octaves.
On the display it's displayed from -8 (flat) to 0 (normal) to 8+ (sharp).
If 8 notes make an octave if I go up or down 1 am I'm changing the key by 2 half steps or one whole step right?
purpletib
Posted: Tue Jun 29, 2010 3:39 pm |
| Advanced Poster |
Joined: Mon Jan 15, 2007 5:22 pm Posts: 263 Been Liked: 0 time
I'm pretty sure Joe has it wrong, the DKC works on HALF NOTES, not half an octave. Hence someone asking about Semitones. Each key change is a half-note. If yours goes up 8 keys and down 8 keys, it allows for a full octave of movement in the form of half and octave down or half an octave up. Refer to this chart for key changes:
http://www.vaughns-1-pagers.com/music/m ... nspose.htm
Avg Joe
Posted: Tue Jun 29, 2010 6:05 pm |
Joined: Tue Jul 14, 2009 10:09 am Posts: 475 Been Liked: 0 time
Babs @ Tue Jun 29, 2010 1:56 am wrote: This is sort of on the same lines of the discussion - I had a guy come in the other night and ask me if I could adjust by semitones. I didn't have a clue what a semitone was. I explained that I could adjust the key or tempo if he'd like. He couldn't explain what one was so when I got home I looked it up. Semitone is a half step.
Semitone? I thought that was not very good singers, semitone deaf
ggardein
Posted: Tue Jun 29, 2010 8:31 pm |
| Advanced Poster |
When we use the key changer, we are really changing the pitch. Pitch and Tempo are two different elements, though some controls change both, by speeding up the media. Frequency is another element that tells you which pitch you are at. Though middle C, and the C which is an octave higher than middle C belong to the same pitch, the higher C has twice the frequency. I'm pretty sure that we call it the Key, as refferenced by the Keys of a piano corresponding to the pitches. I think scientists actually devide each tone into 12 semitones, though on a piano, you can only move by half tones.......feel free to correct me, I'm only human...
ripman8
Posted: Wed Jun 30, 2010 3:52 pm |
Since I only use one source, the key changer on compuhost is simple to use and I've had requests to use it lately. I've found I can use it to sing songs I could not sing otherwise with the very high parts such as Donny Osmond "go away little girl".
Or Boston "more than a feeling".
jclaydon
Posted: Mon Jul 05, 2010 12:28 am |
| Super Duper Poster |
I actually prefer to sing the song in the original key and sing it higher or lower as needed.. *shrug*
Usually works out ok for me at least
Posted: Mon Jul 05, 2010 1:20 am |
jclaydon @ Mon Jul 05, 2010 1:28 am wrote: I actually prefer to sing the song in the original key and sing it higher or lower as needed.. *shrug*
But you are probably maybe 25-30 % of actual singers that know what they want.
hiteck
Posted: Mon Jul 05, 2010 4:06 am |
jclaydon @ Mon Jul 05, 2010 2:28 am wrote: I actually prefer to sing the song in the original key and sing it higher or lower as needed.. *shrug*
-James I'm the same way, but it's nice to have the option for those that want it. I actually bought the piece of equipment for a/v selector 3 in 2 out. I couldn't find a rack mountable solution for less than the $100 I gave. Lonman @ Mon Jul 05, 2010 3:20 am wrote: jclaydon @ Mon Jul 05, 2010 1:28 am wrote: I actually prefer to sing the song in the original key and sing it higher or lower as needed.. *shrug*
-James But you are probably maybe 25-30 % of actual singers that know what they want.
Or even know what they're vocal range is.
jclaydon
Posted: Mon Jul 05, 2010 10:13 am |
you have a point there. Most people don't even know what vocal range is..
As I said in my intro, I was part of a 100 voice choir, so I have a very small amount of music training..
[ 20 posts ] |
Users browsing this forum: No registered users and 2207 guests |
